Looking for intergration with the below , as it works with nest my hope there is an API
They have an API, but it doesn’t appear to be public
http://febrezehomehack.com/#challenges
If you are ok with the works with Nest integration they did, that should continue to work fine.
They seem to key it off of:
nest home / away (which can be controlled via ST if you choose)
they may turn on the hvac fan to move scent around. This may or may not be a good idea depending on how humid of an environment you live in…
