How long does it typically take for AI to finish learning? Mine still shows ‘AI is in learning’ . The AC was installed on the 16th and has run for about 120 hours so far, with roughly 25–30% of that time in AUTO Mode .
When running in AUTO mode and the set temperature (e.g., 26°C) is reached, the compressor gradually slows down to a very low speed, almost as if it’s off. As a result, the room temperature begins to rise slightly from 26°C to 27°C and then the compressor ramps up again to bring the temperature back down to the set level. Once the target temperature is reached, the cycle repeats. Is this behavior normal?
Hello,
Yes, this behavior is normal. In AI Auto mode, the AC learns your preferences over time—120 hours with limited AUTO usage may not be enough to complete learning. The compressor cycling you described is typical for maintaining temperature efficiently without overcooling. dogsounds
OK
But instead of dropping to a very low speed, which causes the room temperature to rise, shouldn’t the AC just slow down enough to maintain the set temperature ?
