How do you configure Aerotec Siren so that opening a sliding glass door creates the sound of one chime but opening garage doors uses a different chime.
It seems that I can pick the endpoint and I get eight options One is a chime the next one is a tamper alarm the next one is a siren but I am looking to use a different sounding chimes to make a different chime sound depending on which doors open just can’t figure it out
I picked the endpoint one (the Default)
And I did figure out that you need to send the configuration but my problem is I can’t figure out how to change sounds 2-8. Sound 1 is the chime and the light flashes. This is what I want but what is I want another sound of the garage doors open. I can’t change them. They are all siren sounds.
It ses like you get 8 different end points but each one is “locked” so sounds 1-8 can’t be changed which just seems wrong.
Isn’t there a way for me to pick my own eight sounds for each one of the chimes instead of having them locked to whatever endpoint I am using. ?
Anyone know how to use several different chimes with the siren. For example if you open the back door it makes a simple chime and if you open a garage door it makes a different chime. I stated in my original message I don’t seem to be able to do this and it’s something that I think should be relatively easy.
