I’m not at a spot to copy paste some code I had into here (will update later) - however I haven’t been successful in getting the LED mode to change on the energy switch… It’s super bright at night, and I’d love to change it to a different mode.
I was trying to do so without luck before leaving for My vacation and currently use it as a night light! Seriously! They are super bright and also has a night light mode too… Currently gets added as a zwave metering switch unless a newer device type is written. Calling out @duncan!
I will be adding dimming preferences. In the meantime you can set the LED behavior with the LED Behavior preference I created. 0 stays on with the outlet and changes color according to amp draw, 1 shows the status for 5 seconds then goes dark and 2 stays in night light mode. I will be adding dimmers for all modes soon.
