I’ve installed a couple aeotec nano switches and control for smartthings have been perfect. However, the local switch does not always work on the first go. If I flip the switch a second time, it’s back on track for local on/off. Any suggestions?
This may or may not be related, but same vendor though. I have a couple WallMotes, on different hubs, using a custom DTH. Both of those don’t always work on the first press either. Interestingly though, the presses show up in the logs, but the ensuing action, either configured in SmartLighting or coded in webCore don’t always fire. Others have experienced the same issue on the WallMotes.
