Aeotec Multisensor (cloud) - Smart Switch 7 (local)
For about a year I have one Aeotec multisensor 6 set in ST with DH Advanced and in IDE I look execution location = Cloud
Today is arrived my new Aeotec Smart Switch 7 set in ST with stock DH and in IDE I look execution location = Local
Is that correct?
Depends on the DH?
Can I have the Multisensor in Local too?
Just depends on the dth. No custom dth will run locally, even if you define it as local. And even some stock dths run in the cloud. For example Zigbee Motion/Temp/Humidity Sensor is stock but executes in the cloud.
Yes you can have the Multi 6 running locally, change dth to the official one at the top of the list.
OK, but if I change the dth with the official one I lose the setting?
Depends on the DTH, if the new device handler defaults a particular setting during its install routine then it will change - i fnot then the settings that aren’t overwritten will stick.
(In the case of the Aeotec - I do this regularly. The custom to setup settings (like forcing to powered mode) but use the builtin for normal ops.)
Is there a custom DTH for the Aeotec Smart Switch 7? I just got one, and the power meter doesn’t update.
