I just added my Aeotec multisensor 6 to my Aeotec smartthings hub. Everything seems to work ok except the illuminance is “stuck” at -32,768. Any idea what might be causing this. It has been connected about 24 hours so far and no change.
Welcome to the Dark Side
Maybe @erocm1231 can help
It almost sounds like it didn’t join properly. I assume all the other attributes are working ok?
I looked at the DTH on ST’s github repo, and unfortunately it only sends logging info for configuration events, but it still may be worthwhile to look at live logging in the IDE just in case. You can try changing a device setting, which will generate live logging events.
Is it in a really bright location?
You could try another device handler to see if the issue clears up.
