I have not seen a way to do this, but I haven’t checked out IFTTT for a while. I used to use that to send a excel file to my email so I could see all of the data, but don’t do that anymore.
I am not able to access the invitation link, getting the following error, while clicking on the direct invite link - Forbidden
You do not have permission to access the specified invitation
Is the invitation link broken ?
There appears to be an issue at the moment. Discussion is here…
Ok… just an update.
I found a similar app instead of webcore, actually its easier to use. https://sharptools.io/ has everything I need. I am able to monitor my Aeotec device for power levels and daily/weekly/monthly energy usage reports.
thanks, michael
Hi all,
Is there any alternative driver for this clamp power meter? With the last Aeotec driver it’s not showing the history of energy consumption anymore:
BTW, is there any possibility to change the readings from Wh to kWh?
Hola @norberto_bcn
This is new in the last app version, not issue of the driver.
The app change automatically the unitis to kwh when value will be greater than 1 kwh
Thank you @Mariano_Colmenarejo for your reply You’re the best!
