Aeotec Gen 5 recessed door contact stopped working
I have 3 Aeotec Gen 5 recessed door contacts and one of them stopped working on 7/19. I’ve changed battery. Also deleted, and readded, but all I get is "This device hasn
TG
Your sensors were probably automatically migrated from an old Device Handler to a new Edge Driver.
You could check the driver by opening device tab, click on 3 dots, then click on driver. It should list the driver being used. You could hit change driver and see if you have any options.
Things to try:
  1. Open and close door or window several times to see if that helps.
  2. Exclude and re-pair the device next to your hub.
  3. Add some community drivers such as Z-Wave Sensor PH or Z-Wave Sensor CS and then try changing the driver as mentioned above.
Aeotec also provides a driver.
