Here’s my device type based off the original, but made to work for this specific product (switch not dimmer) and report information correctly.
- Copyright 2015 SmartThings and gpsmith
- Based on original implementation by SmartThings but fixed some of the issues.
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
metadata {
definition (name: “Aeon Outlet DEBUG”, namespace: “gpsmith”, author: “SmartThings and gpsmith”) {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Configuration"
capability "Polling"
capability "Refresh"
capability “Sensor”
command "reset"
fingerprint deviceId: "0x1001", inClusters: "0x25,0x32,0x27,0x2C,0x2B,0x70,0x85,0x56,0x72,0x86", outClusters: "0x82"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV2.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
tiles (scale: 2) {
multiAttributeTile(name:"switch", type:"lighting", width:6, height:4, canChangeIcon: true) {
tileAttribute("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#fdbc32"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
valueTile("power", "device.power", decoration: "flat", width: 3, height: 2) {
state "power", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat", width: 3, height: 2) {
state "default", label:'${currentValue} kWh\n(total)'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'reset kWh', action:"reset"
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","energy","power","refresh","reset","configure"])
//details(["switch","energy","reset","refresh","configure"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x32: 3])
if (cmd) {
log.debug cmd
result = createEvent(zwaveEvent(cmd))
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
if (cmd.scale == 0) {
[name: “energy”, value: (String.format("%6.3f", cmd.scaledMeterValue)), unit: “kWh”]
} else if (cmd.scale == 1) {
[name: “energy”, value: cmd.scaledMeterValue, unit: “kVAh”]
else {
//log.debug “Fallen to W”
[name: “power”, value: Math.round(cmd.scaledMeterValue), unit: “W”]
v2 didn’t seem to be working.
def zwaveEvent(physicalgraph.zwave.commands.meterv2.MeterReport cmd) {
[name: “energy”, value: cmd.scaledMeterValue, unit: “kWh”]
else {
debug.log “Fallen to W”
//[name: “power”, value: Math.round(cmd.meterValue), unit: “W”]
//[name: “power”, value: Math.round(cmd.scaledMeterValue), unit: “W”]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”
// Handles all Z-Wave commands we aren’t interested in
//log.debug “Unhandled: ${cmd}”
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.meterV2.meterGet().format()
def refresh() {
def reset() {
return [
zwave.meterV2.meterReset().format(),
def configure() {
log.debug "Send Configuration to device"
delayBetween([
//zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 8).format(), // energy in kWh
//zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300).format(), // every 5 min
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 4).format(), // energy in Watts
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 5).format(), // every 5 sec
zwave.configurationV1.configurationSet(parameterNumber: 91, size: 2, scaledConfigurationValue: 1).format(), // Send report for a 1W change
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 8).format(), // energy in kWh
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 300).format() // every 5 min
