I have developed this device type, which reports within a second, unfortunately the hue light I control off of the switch takes 3 seconds to dim on or off
metadata {
// Automatically generated. Make future change here.
definition (name: "GG - Aeon Micro Switch", namespace: "ggrouwstra", author: "Garrette Grouwstra") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Power Meter"
command "reset"
fingerprint deviceId: "0x1001", inClusters: "0x25,0x32,0x27,0x2C,0x2B,0x70,0x85,0x56,0x72,0x86", outClusters: "0x82"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
for (int i = 0; i <= 10000; i += 1000) {
status "power ${i} W": new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
// reply messages
reply "2001FF,delay 100,2502": "command: 2503, payload: FF"
reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
valueTile("power", "device.power", decoration: "flat") {
state "default", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat") {
state "default", label:'${currentValue} kWh1'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat") {
state "default", label:'reset kWh', action:"reset"
standardTile("configure", "device.power", inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch","power","energy","reset","configure","refresh"])
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x32: 1])
if (cmd) {
log.debug cmd
result = createEvent(zwaveEvent(cmd))
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv2.MeterReport cmd) {
if (cmd.scale == 0) {
[name: "energy", value: cmd.scaledMeterValue, unit: "kWh"]
} else if (cmd.scale == 1) {
[name: "energy", value: cmd.scaledMeterValue, unit: "kVAh"]
else {
[ name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W" ]
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
def map = null
if (cmd.meterType == 1) {
map = [name: "energy", value: cmd.scaledMeterValue, unit: "kWh"]
map = [name: "energy", value: cmd.scaledMeterValue, unit: "kVAh"]
} else if (cmd.scale == 2) {
map = [name: "power", value: cmd.scaledMeterValue, unit: "W"]
} else {
map = [name: "electric", value: cmd.scaledMeterValue]
map.unit = ["pulses", "V", "A", "R/Z", ""][cmd.scale - 3]
} else if (cmd.meterType == 2) {
map = [name: "gas", value: cmd.scaledMeterValue]
map.unit = ["m^3", "ft^3", "", "pulses", ""][cmd.scale]
} else if (cmd.meterType == 3) {
map = [name: "water", value: cmd.scaledMeterValue]
map.unit = ["m^3", "ft^3", "gal"][cmd.scale]
if (map) {
if (cmd.previousMeterValue && cmd.previousMeterValue != cmd.meterValue) {
map.descriptionText = "${device.displayName} ${map.name} is ${map.value} ${map.unit}, previous: ${cmd.scaledPreviousMeterValue}"
createEvent(map)
} else {
null
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
name: "switch", value: cmd.value ? "on" : "off", type: "physical"
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
def map = []
map = [ name: "energy", value: cmd.scaledMeterValue, unit: "kWh" ]
map = [ name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W" ]
map
def zwaveEvent(int endPoint, physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
// MeterReport(deltaTime: 1368, meterType: 1, meterValue: [0, 3, 29, 17], precision: 3, previousMeterValue: [0, 3, 29, 17], rateType: 1, reserved02: false, scale: 0, scaledMeterValue: 204.049, scaledPreviousMeterValue: 204.049, size: 4)
log.debug "EndPoint $endPoint, MeterReport $cmd"
def map = []
map = [ name: "energy" + endPoint, value: cmd.scaledMeterValue, unit: "kWh" ]
map = [ name: "power" + endPoint, value: Math.round(cmd.scaledMeterValue), unit: "W" ]
map
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
name: "switch", value: cmd.value ? "on" : "off", type: "digital"
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug "Configuration Report for parameter ${cmd.parameterNumber}: Value is ${cmd.configurationValue}, Size is ${cmd.size}"
def zwaveEvent(physicalgraph.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
log.debug "Capture All $cmd"
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.meterV2.meterGet().format(),
zwave.meterV2.meterGet(scale:0).format(),
zwave.meterV2.meterGet(scale:2).format()
def refresh() {
delayBetween([
zwave.meterV2.meterGet(scale: 0).format(), // get kWh
zwave.meterV2.meterGet(scale: 2).format(), // Get Watts
zwave.basicV1.basicGet().format(),
], 1200)
def reset() {
return [
zwave.meterV2.meterReset().format(),
def configure() {
log.debug "Seting Configuration to switch"
delayBetween([
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format(), // Current Overload Protection
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 4).format(), // combined power in watts
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 8).format(), // combined energy in kWh
zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 2).format(), // every 2 sec
zwave.configurationV1.configurationSet(parameterNumber: 112, size: 4, scaledConfigurationValue: 120).format(), // every 2 min
zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 120).format(), // every 2 min
zwave.configurationV1.configurationSet(parameterNumber: 102, size: 4, scaledConfigurationValue: 0).format(),
zwave.configurationV1.configurationSet(parameterNumber: 103, size: 4, scaledConfigurationValue: 0).format(), // no third report
zwave.configurationV1.configurationSet(parameterNumber: 80, size: 1, scaledConfigurationValue: 2).format(), // Instant reporting
zwave.configurationV1.configurationSet(parameterNumber: 113, size: 4, scaledConfigurationValue: 300).format() // every 5 min
def result = zwave.configurationV1.configurationGet(parameterNumber: 80).format()
log.debug "Parameter 80 $result"
