johnlaroux
(John LaRoux)
March 26, 2017, 10:26pm
1
How can I change the polliing frequency from 10 seconds to about 30 minutes???
My aeon metering switches poll every 10 seconds and causes too much traffic.
tgauchat
March 26, 2017, 10:33pm
2
Search is your friend: There are probably, literally, a dozen Topics on this issue (various different Device models / vendors though!!!); I’m not sure which has the best “answer” …
Here is the code to only display once an hour, Go to IDE and add device handler.
Then delete your connected smart outlet and re connect it and it should connect using the new device handler
https://graph.api.smartthings.com/ide/devices
to reset/reconnect device:
from sticks18 “To reset, unplug the outlet. Then while holding the button, plug the outlet in. When the LED comes on, release the button. It should now be reset. Start the Connect New Device procedure in the app and give it a few minutes. It probably won’t register that a new device is connected since the outlet already exists in your setup. (If you have Live Logging in the IDE up while the app searches for new devices, you should be able to see it rejoin.)”
* Copyright 2015 SmartThings
* Licensed under the Apache …
Well… for a start; someone just has to play with the ZigBee Power Reporting config commands. They are documented in the ZCL (ZigBee Cluster Library), I think, but also may be specific to the manufacturer / model.
Once we know how to successfully tweak these, then it can be done via DTH parameters.
Okay, I actually fixed it so the tile now reports the power usage continuously. Turning off the setting just removes the reporting from the activity feed, or restricts it to only when the power usage changes by the set amount.
