I installed this today along with the DTH from https://gist.github.com/DuncanIdahoCT. I have the two phase/two clamps on the two mains coming into the panel, I made sure to have one with the arrow facing up, one with the arrow facing down. I have tried switching the clamps from each pole, the results being the same except showing 0 values for one of the poles. Also, after all the breakers have been shut off (except the dedicated 20amp I have the HEM hardwires to), it still shows some wattage in one of the tiles, although according to my log and looking at the actual device on smart things, its reporting 0, as there is no usage. Pretty confused here, shouldnât I see some activity for the second clamp on a standard US 2 phase 200amp service? Why would clamp direction even matter with AC powerâŠthen after shutting everything off, one tile will continue to say 330W when the actual is 0W
Here are the debug logs from my DTH:
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:26 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 85 03 01 05 00 01 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:26 PM: debug âASSOCIATION REPORT V2â Energy Meter (Shop) groupingIdentifier: 1, maxNodesSupported: 5, nodeId: [1], reportsToFollow: 0
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:26 PM: debug encapsulated: AssociationReport(groupingIdentifier: 1, maxNodesSupported: 5, nodeId: [1], reportsToFollow: 0)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:26 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 71 04 00 00 00 06 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:26 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 113 with a byte size of 4 is set to [0, 0, 0, 6]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:26 PM: debug encapsulated: ConfigurationReport(configurationValue: [0, 0, 0, 6], parameterNumber: 113, reserved11: 0, scaledConfigurationValue: 6, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:25 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 70 04 00 00 00 1E â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:25 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 112 with a byte size of 4 is set to [0, 0, 0, 30]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:25 PM: debug encapsulated: ConfigurationReport(configurationValue: [0, 0, 0, 30], parameterNumber: 112, reserved11: 0, scaledConfigurationValue: 30, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:25 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 6F 04 00 00 00 3C â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:25 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 111 with a byte size of 4 is set to [0, 0, 0, 60]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:25 PM: debug encapsulated: ConfigurationReport(configurationValue: [0, 0, 0, 60], parameterNumber: 111, reserved11: 0, scaledConfigurationValue: 60, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:24 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 66 04 00 18 00 08 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:24 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 102 with a byte size of 4 is set to [0, 24, 0, 8]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:24 PM: debug encapsulated: ConfigurationReport(configurationValue: [0, 24, 0, 8], parameterNumber: 102, reserved11: 0, scaledConfigurationValue: 1572872, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:24 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 67 04 00 00 03 02 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:24 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 103 with a byte size of 4 is set to [0, 0, 3, 2]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:24 PM: debug encapsulated: ConfigurationReport(configurationValue: [0, 0, 3, 2], parameterNumber: 103, reserved11: 0, scaledConfigurationValue: 770, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:23 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 65 04 00 00 18 05 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:23 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 101 with a byte size of 4 is set to [0, 0, 24, 5]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:23 PM: debug encapsulated: ConfigurationReport(configurationValue: [0, 0, 24, 5], parameterNumber: 101, reserved11: 0, scaledConfigurationValue: 6149, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:22 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 70 06 08 01 05 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:22 PM: debug âCONFIGURATION REPORT V1â Energy Meter (Shop) parameter 8 with a byte size of 1 is set to [5]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:22 PM: debug encapsulated: ConfigurationReport(configurationValue: [5], parameterNumber: 8, reserved11: 0, scaledConfigurationValue: 5, size: 1)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:20 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 60 0D 01 00 32 02 21 64 00 00 00 00 00 40 00 00 00 00 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:20 PM: debug encapsulated: MultiChannelCmdEncap(bitAddress: false, command: 2, commandClass: 50, destinationEndPoint: 0, parameter: [33, 100, 0, 0, 0, 0, 0, 64, 0, 0, 0, 0], sourceEndPoint: 1)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:19 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 60 0D 02 00 32 02 21 64 00 00 00 00 00 40 00 00 00 00 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:19 PM: debug encapsulated: MultiChannelCmdEncap(bitAddress: false, command: 2, commandClass: 50, destinationEndPoint: 0, parameter: [33, 100, 0, 0, 0, 0, 0, 64, 0, 0, 0, 0], sourceEndPoint: 2)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:19 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 60 0D 02 00 32 02 A1 6C 00 00 00 00 00 00 00 00 00 00 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:19 PM: debug encapsulated: MultiChannelCmdEncap(bitAddress: false, command: 2, commandClass: 50, destinationEndPoint: 0, parameter: [161, 108, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], sourceEndPoint: 2)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:18 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 60 0D 01 00 32 02 A1 6C 00 00 00 00 00 00 00 00 00 00 â to null
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:18 PM: debug encapsulated: MultiChannelCmdEncap(bitAddress: false, command: 2, commandClass: 50, destinationEndPoint: 0, parameter: [161, 108, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], sourceEndPoint: 1)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:17 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 32 02 21 64 00 00 00 00 00 0D 00 00 00 00 â to [ânameâ:âenergyâ, âunitâ:âkWhâ, âdisplayedâ:false, âvalueâ:0.000, âisStateChangeâ:false, âlinkTextâ:âEnergy Meter (Shop)â, âdescriptionTextâ:Energy Meter (Shop) energy is 0.000 kWh]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:17 PM: debug encapsulated: MeterReport(deltaTime: 13, meterType: 1, meterValue: [0, 0, 0, 0], precision: 3, previousMeterValue: [0, 0, 0, 0], rateType: 1, scale: 0, scale2: false, scaledMeterValue: 0.000, scaledPreviousMeterValue: 0.000, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:17 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 32 02 A1 6C 00 00 00 00 00 00 00 00 00 00 â to [ânameâ:âcurrentâ, âunitâ:âAâ, âdisplayedâ:false, âvalueâ:0.000, âisStateChangeâ:false, âlinkTextâ:âEnergy Meter (Shop)â, âdescriptionTextâ:Energy Meter (Shop) current is 0.000 A]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:17 PM: debug encapsulated: MeterReport(deltaTime: 0, meterType: 1, meterValue: [0, 0, 0, 0], precision: 3, previousMeterValue: [0, 0, 0, 0], rateType: 1, scale: 5, scale2: false, scaledMeterValue: 0.000, scaledPreviousMeterValue: 0.000, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:06 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 32 02 A1 64 00 01 E3 F5 00 00 00 00 00 00 â to [ânameâ:âvoltageâ, âunitâ:âVâ, âdisplayedâ:true, âvalueâ:123.893, âisStateChangeâ:true, âlinkTextâ:âEnergy Meter (Shop)â, âdescriptionTextâ:Energy Meter (Shop) voltage is 123.893 V]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:06 PM: debug encapsulated: MeterReport(deltaTime: 0, meterType: 1, meterValue: [0, 1, 227, 245], precision: 3, previousMeterValue: [0, 0, 0, 0], rateType: 1, scale: 4, scale2: false, scaledMeterValue: 123.893, scaledPreviousMeterValue: 0.000, size: 4)
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:05 PM: debug Sending configure commands - kWhCost â0.0685â, monitorInterval1 â60â, monitorInterval2 â30â, monitorInterval3 â6â
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:04 PM: debug Parsed 'zw device: 21, command: 9881, payload: 00 32 02 21 64 00 00 00 00 00 32 00 00 00 00 â to [ânameâ:âenergyâ, âunitâ:âkWhâ, âdisplayedâ:false, âvalueâ:0.000, âisStateChangeâ:false, âlinkTextâ:âEnergy Meter (Shop)â, âdescriptionTextâ:Energy Meter (Shop) energy is 0.000 kWh]
a465e7ca-659a-4b27-abdf-8fa1518c427e 10:54:04 PM: debug encapsulated: MeterReport(deltaTime: 50, meterType: 1, meterValue: [0, 0, 0, 0], precision: 3, previousMeterValue: [0, 0, 0, 0], rateType: 1, scale: 0, scale2: false, scaledMeterValue: 0.000, scaledPreviousMeterValue: 0.000, size: 4)
