Aeon Labs Energy Meter clamps
I ended up writing up one from scratch for my laundry monitor solution.
It currently presses button 1 when the washer wattage falls below the value configured in preferences.
And button 2 when the dryer falls below it’s preference wattage.
You’re looking for the opposite sort of thing, but this would give you a much better starting device type.
It includes the correct configuration settings to enable independent reporting for each probe.
Custom Laundry monitor device for Aeon HEM V1
metadata {
	definition (name: "Aeon HEM V1 Laundry DTH", namespace:	"MikeMaxwell", author: "Mike Maxwell")
		capability "Configuration"
		capability "Switch"
        capability "Button"
        //capability "Energy Meter"
        attribute "washerWatts", "string"
        attribute "dryerWatts", "string"
        attribute "washerState", "string"
        attribute "dryerState", "string"
        command "configure"
		fingerprint deviceId: "0x2101", inClusters: " 0x70,0x31,0x72,0x86,0x32,0x80,0x85,0x60"
	preferences {
       	input name: "washerRW", type: "number", title: "Washer running watts:", description: "", required: true
        input name: "dryerRW", type: "number", title: "Dryer running watts:", description: "", required: true
    simulator {
	tiles(scale: 2) {
    	multiAttributeTile(name:"laundryState", type: "generic", width: 6, height: 4){
        	tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
            	attributeState "on", label:'Running', icon:"st.Appliances.appliances1", backgroundColor:"#79b821"
            	attributeState "off", label:'Nothing running', icon:"st.Appliances.appliances1", backgroundColor:"#ffffff"
        valueTile("washerState", "device.washerState", width: 3, height: 2) {
        	state("on", label:'Washer:\nRunning', backgroundColor:"#79b821")
            state("off", label:'Washer:\nNot running', backgroundColor:"#ffffff")
        valueTile("dryerState", "device.dryerState", width: 3, height: 2) {
        	state("on", label:'Dryer:\nRunning', backgroundColor:"#79b821")
            state("off", label:'Dryer:\nNot running', backgroundColor:"#ffffff")
        valueTile("washer", "device.washerWatts", width: 3, height: 1, decoration: "flat") {
        	state("default", label:'Washer\n${currentValue}\nWatts', foregroundColor: "#000000")
        valueTile("dryer", "device.dryerWatts", width: 3, height: 1, decoration: "flat") {
        	state("default", label:'Dryer\n${currentValue}\nWatts', foregroundColor: "#000000")
		standardTile("configure", "command.configure", inactiveLabel: false) {
			state "configure", label:'', action: "configure", icon:"st.secondary.configure"
		main "laundryState"
		details(["laundryState","washerState","dryerState","washer","dryer","configure"])
def installed() {
	configure()
//	log.debug "Parse received ${description}"
	def result = null
	def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
	if (cmd) {
		result = createEvent(zwaveEvent(cmd))
	if (result) {
		//log.debug "Parse returned ${result?.descriptionText}"
		return result
	} else {
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
	//log.info "mc3v cmd: ${cmd}"
	if (cmd.commandClass == 50) {
    	def encapsulatedCommand = cmd.encapsulatedCommand([0x30: 1, 0x31: 1])
        if (encapsulatedCommand) {
        	def scale = encapsulatedCommand.scale
        	def value = encapsulatedCommand.scaledMeterValue
            def source = cmd.sourceEndPoint
            def str = ""
            def name = ""
        	if (scale == 2 ){ //watts
            	str = "watts"
                if (source == 1){
                	name = "washerWatts"
                    if (value >= settings.washerRW.toInteger()){
                    	//washer is on
                        sendEvent(name: "washerState", value: "on", displayed: false)
                        state.washerIsRunning = true
                    } else {
                    	//washer is off
                        if (state.washerIsRunning == true){
                        	//button event
                            sendEvent(name: "button", value: "pushed", data: [buttonNumber: 1], descriptionText: "Washer has finished.", isStateChange: true)
                        sendEvent(name: "washerState", value: "off", displayed: false)
                        state.washerIsRunning = false
                } else {
                	name = "dryerWatts"
                    if (value >= settings.dryerRW.toInteger()){
                    	//dryer is on
                        sendEvent(name: "dryerState", value: "on", displayed: false)
                        state.dryerIsRunning = true
                    } else {
                    	//dryer is off
                        if (state.dryerIsRunning == true){
                        	//button event
                            sendEvent(name: "button", value: "pushed", data: [buttonNumber: 2], descriptionText: "Dryer has finished.", isStateChange: true)
                        sendEvent(name: "dryerState", value: "off", displayed: false)
                        state.dryerIsRunning = false
                if (state.washerIsRunning || state.dryerIsRunning){
                	sendEvent(name: "switch", value: "on", descriptionText: "Laundry has started...", displayed: true)
                } else {
                	sendEvent(name: "switch", value: "off", displayed: false)
                //log.debug "washerIsRunning: ${state.washerIsRunning}, dryerIsRunning: ${state.dryerIsRunning}"
            	return [name: name, value: value.toInteger(), unit: str, displayed: false]
def zwaveEvent(physicalgraph.zwave.Command cmd) {
	// Handles all Z-Wave commands we aren't interested in
    log.debug "Unhandled event ${cmd}"
def configure() {
	log.debug "configure()"
	def cmd = delayBetween([
    	//zwave.configurationV1.configurationSet(parameterNumber: 100, size: 4, scaledConfigurationValue:1).format(),	//reset if not 0
        //zwave.configurationV1.configurationSet(parameterNumber: 110, size: 4, scaledConfigurationValue: 1).format(),	//reset if not 0
    	zwave.configurationV1.configurationSet(parameterNumber: 1, size: 2, scaledConfigurationValue: 120).format(),		// assumed voltage
		zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: 0).format(),			// Disable (=0) selective reporting
		zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, scaledConfigurationValue: 10).format(),			// Or by 10% (L1)
      	zwave.configurationV1.configurationSet(parameterNumber: 10, size: 1, scaledConfigurationValue: 10).format(),			// Or by 10% (L2)
		zwave.configurationV1.configurationSet(parameterNumber: 20, size: 1, scaledConfigurationValue: 1).format(),			//usb = 1
		zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 6912).format(),
		zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 60).format() 		// Every 60 seconds
	], 2000)
	return cmd
