ahadahad
(MEIRI OHAD)
1
hi, i’m using the product for a while and it works OK.
i was easily paired to the HUB although it was paired as an outlet.
the only problem is - that it doesn’t report KWH.
if anyone managed to make it report energy consumption - i’ll be grateful to know how to do it.
thanx
ohad
ero4444
(Eric)
2
you may have to login to IDE
https://graph.api.smartthings.com/
and edit the device to type “Aeon Outlet” which shows KWH
but it will not show KW
ahadahad
(MEIRI OHAD)
3
hello, and thanx for the reply.
as i mentioned, it is already paired as an outlet.
ero4444
(Eric)
4
I have one of these Aeon labs DSC18103-ZWUS installed, and KWH updates.
Did you try what I suggested SPECIFICALLY “Aeon Outlet” ?
Not “Outlet”. “Outlet” is not specific.
ahadahad
(MEIRI OHAD)
5
hi, thanx again.
i’m using AEON OUTLETS - still no KWH.
