I just paired it up and it would work. Maybe unpair and re-pair? For the events what is it giving? I know it would say BOTH when it would activate. Once it shows under things, you should be able to tap it to turn it on and off.
Thanks @smart and @jpetrone! I canāt explain what went wrong the first time I tried⦠but after a force delete from the hub and a factory reset on the device, I just tried again and Iām in business!
If it worked with the Z-Wave Siren device type the first time, it probably failed secure inclusion due to some random error and joined as a non-secure device. This device can work on both security-enabled networks and non-secure, so since our hub supports security it automatically tries a secure join and if successful it will refuse non-secure commands like the normal Z-Wave Siren handler sends.
Thatās one sexy siren. Is this a z-wave repeater like the Fortrezz? Also, is ST able to take advantage of the different light alerts yet?
Yes, itās a repeater. What do you mean about different light alerts?
Thanks @duncan
From aeotec.comā¦
Visual alerts.
Itās not just Sirenās audio alerts that are helping to keep you safe. Siren is enhanced with visual alerts courtesy of 3 powerful, front-facing LEDs.
Wondering if the current device type can handle the visual alerts aeotec describes.
Iām pretty sure that just means that the siren has LEDs that flash when it goes off.
Got it. I donāt know why I read that as there were different visual alerts. Got my wires crossed.
So Iāve had trouble pairing the siren. Canāt seem to get ST to recognize it. Additionally, Iām noticing that there is a low hiss coming from the siren when itās plugged in. Itās scary putting your ear up to it. Anyone else hearing that sound? @mkmark @smart ?
Strange. I never heard any hissing sound.i got it paired the first day @duncan posted the device type and has been working for me and I have occasionally been testing it.
Hey @ultrazero, sorry for the delay. I just checked my unit (which is still working great) ā youāre absolutely right, there is a faint hiss/static sound when I put my ear directly up against it. I never noticed it before, and I couldnāt notice it once I moved more than about 6 inches away. It doesnāt bother me, but can see how it might for others with more sensitive hearing.
Thanks Mark. That makes me feel a bit better. Additionally, I got my siren paired today. Was having all kinds of pairing problems with a bunch of devices and reseting the hub worked great. This paired right up. Seems to work well, so Iām happy.
The one thing Iād really like to do is use the different alert sounds (at different volumes) for different purposes. So for example, one would be the main security alarm. Another would be an alert for a flood, etc. Has anyone had any luck with this? Does this require itās own smartapp?
The siren sounds whenever you change the settings, so that can be used to create commands for the different sounds. Hereās an example:
The downside is that it changes the setting ā the next time you just send āonā, it will use the last sound. So you kind of have to always use the individual sound methods.
As I progress through setting up ST in my new home, Iām looking at Smart Alarm and need a siren. This one (or two) seems to fit the bill due to its plug in form factor.
My questions though, are:
Can I use more than one, say one in the basement and one on my
second floor, and have them respond in the same way and at the same
time?
Can this be used as an audio indicator for door
openings/closings like with a traditional alarm system? E.g., my
in-lawās wired alarm chirps a door is open.
@John_Esher Iām sure the siren could be used as a chime but a smart app would need to be created in an attempt to achieve that. The Smart Alarm smart app, presently can not support that function.
I believe there is only one spot to choose a siren. So I think you would have to install/run two instances of the smart alarm app in order to achieve two sirens going at once.
You can also try asking the 2 siren question in the smart alarm post.
@ultrazero, Iām also hearing that high-pitched whine with my Aeon siren. My wife hears it two rooms away and she canāt stand it. Now that she has pointed it out, I canāt help noticing it either.
I assume this is part of the hardware that I canāt modify, and is likely to be the same with other Aeon sirens.
Does anyone have direct experience with the Fortrezz alarm, and have you noticed a high-pitched whine coming from that? I have to admit, this Aeon paired very easily with my hub and it looks really great (way better than the red globe on the Fortrezz). But Iād be willing to sacrifice looks for a device that doesnāt whine.
Same questions here, I want to be able to use it as a chime (Door Open/Close)
Hey Guys, bit of a noob here. Just got my Aeon Labs siren and I would like for it to go off when someone enters the house and neither my wife or I are home. can someone walk me through how they would do this?
Assuming you have presence set up with either your phones or with ST presence fobs, the best option is to use @gekoās amazing smart alarm app.
I just bought one of these and it took some effort to get it to pair. Now, I canāt test it and the activity page is completely blank. Iāve also tried to exclude it to no avail.
I had an issue when I first tried to pair the siren as well. I ended up rebooring my hub through the IDE and that did the trick. Paired right away. Rebooting actually solved a bunch of other issues I was having as well. Maybe itāll work for you?
