Aeon gen5 Siren problem
I have installer my Aeon gen5 Siren and it shows up under “things”. The problem is that I can not get in contact with it. And I can not remove it (even with force).
Here are some suggestions for removing the device:
  • The device needs to be removed from any SmartApps that may be using it.
  • When you remove it through the mobile app you should press the button on the siren to complete the exclusion.
  • If you moved the device after pairing it, it might be too far away from the hub so you should try moving it closer.
  • If all else fails, delete it from the IDE and perform a factory reset on the device by holding down the button for about 20 seconds.
Other users with similar problems have had better luck with the device handler below.
Thank you! I did not know that I had to press the button on The Siren
