Advanced zwave dimmer switch w color control for cooper and eaton switches
For those of you like me that have hooked up hue lights so they are always on and use switches like the cooper or eaton etc switch with a dimmer control ie
This is the device driver/handler i use that also has been updated for the new smartthings mobile app so it correctly shows the switch state (on/off) in the dashboard view and also has all the features
(ie swtich , color control, dimmer) in the detail view.
I wire my bulbs on all the time so they dont get turned off but still want a switch to control them in the wall. I use color coord smart app to cordinate… In this way you can change the color in the app on the switch and all the synced hue lights also change.
Also the separate dimmer up/down on the switch works as well
  • Copyright 2015 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • lgk a few changes
    1. switch level capability so level changes get passed through and received from other apps
  • like dim with me. Now you can have this control a set of lights and dim based on this.
  • also reduced delays as the ge switches delay enough.
  • Finally, Added color control capability, rgb control tiles and associated functions,
  • and a color control tile… I know the switch has nothing
  • to do with color. But since you use this device type to control slave lamps using either smart lighting
  • smart app or dim with me smartapp. Once this is in place you can use the color coordinator smartapp
  • and make this device the master to control the slave bulbs.
  • also works with other dimmers. Tested with GE (have delay) and Cooper (Instant). Can control hue lights with
  • no load hooked up. Recommend using Color with me App.
metadata {
definition (name: “Advanced Zwave Dimmer Switch w Color Control V2”, namespace: “lgkapps”, author: “kahn@lgk.com”, mnmn: “SmartThingsCommunity”, vid: “3c16e1df-31b3-326e-91f4-215267497679” )
capability “Actuator”
capability “Indicator”
capability “Switch”
capability “Polling”
capability “Refresh”
capability “Sensor”
capability “Switch Level”
capability “Color Control”
capability “Health Check”
    command "setColor"
    command "setAdjustedColor"
	fingerprint inClusters: "0x26"
simulator {
	status "on":  "command: 2003, payload: FF"
	status "off": "command: 2003, payload: 00"
	status "09%": "command: 2003, payload: 09"
	status "10%": "command: 2003, payload: 0A"
	status "33%": "command: 2003, payload: 21"
	status "66%": "command: 2003, payload: 42"
	status "99%": "command: 2003, payload: 63"
	// reply messages
	reply "2001FF,delay 5000,2602": "command: 2603, payload: FF"
	reply "200100,delay 5000,2602": "command: 2603, payload: 00"
	reply "200119,delay 5000,2602": "command: 2603, payload: 19"
	reply "200132,delay 5000,2602": "command: 2603, payload: 32"
	reply "20014B,delay 5000,2602": "command: 2603, payload: 4B"
	reply "200163,delay 5000,2602": "command: 2603, payload: 63"
tiles(scale: 2) {
	multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
		tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
			attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
			attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
			attributeState "turningOn", label:'${name}', action:"", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
			attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
		tileAttribute ("device.level", key: "SLIDER_CONTROL") {
			attributeState "level", action:"switch level.setLevel"
controlTile(“rgbSelector”, “device.color”, “color”, height: 6, width: 4, inactiveLabel: false) {
state “color”, action:“setAdjustedColor”
standardTile(“indicator”, “device.indicatorStatus”, height: 2, width: 2, inactiveLabel: false, decoration: “flat”) {
state “when off”, action:“indicator.indicatorWhenOn”, icon:“st.indicators.lit-when-off”
state “when on”, action:“indicator.indicatorNever”, icon:“st.indicators.lit-when-on”
state “never”, action:“indicator.indicatorWhenOff”, icon:“st.indicators.never-lit”
standardTile(“refresh”, “device.switch”, height: 2, width: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:"", action:“refresh”, icon:“st.secondary.refresh”
	main(["switch"])
	details(["switch", "rgbSelector","refresh", "indicator"])
def item1 = [
canBeCurrentState: false,
linkText: getLinkText(device),
isStateChange: false,
displayed: false,
descriptionText: description,
value: description
log.debug "in parse desc = $description"
def result
def cmd = zwave.parse(description, [0x20: 1, 0x26: 1, 0x70: 1])
if (cmd) {
	result = createEvent(cmd, item1)
else {
	item1.displayed = displayed(description, item1.isStateChange)
	result = [item1]
log.debug "Parse returned ${result?.descriptionText}"
result
def createEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd, Map item1) {
def result = doCreateEvent(cmd, item1)
for (int i = 0; i < result.size(); i++) {
result[i].type = “physical”
result
def createEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd, Map item1) {
result
def createEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelStartLevelChange cmd, Map item1) {
def createEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd, Map item1) {
[response(zwave.basicV1.basicGet())]
def createEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelSet cmd, Map item1) {
result
def createEvent(physicalgraph.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd, Map item1) {
result[0].descriptionText = “{item1.linkText} is {item1.value}”
result[0].handlerName = cmd.value ? “statusOn” : “statusOff”
log.debug "result size = $result.size"
	result[i].type = "digital"
result
def doCreateEvent(physicalgraph.zwave.Command cmd, Map item1) {
def result = [item1]
log.debug “in create event cmd = cmd" item1.name = "switch" item1.value = cmd.value ? "on" : "off" item1.handlerName = item1.value item1.descriptionText = "{item1.linkText} was turned ${item1.value}”
item1.canBeCurrentState = true
item1.isStateChange = isStateChange(device, item1.name, item1.value)
item1.displayed = item1.isStateChange
if (cmd.value >= 5) {
	def item2 = new LinkedHashMap(item1)
	item2.name = "level"
	item2.value = cmd.value as String
	item2.unit = "%"
	item2.descriptionText = "${item1.linkText} dimmed ${item2.value} %"
	item2.canBeCurrentState = true
	item2.isStateChange = isStateChange(device, item2.name, item2.value)
	item2.displayed = false
    def  intlevel = item2.value as Integer
     setLevel(item2.value)// sendEvent(name:"switch.setLevel",value:intlevel)
	result << item2
result
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
def value = “when off”
if (cmd.configurationValue[0] == 1) {value = “when on”}
if (cmd.configurationValue[0] == 2) {value = “never”}
[name: “indicatorStatus”, value: value, display: false]
def createEvent(physicalgraph.zwave.Command cmd, Map map) {
// Handles any Z-Wave commands we aren’t interested in
log.debug “UNHANDLED COMMAND $cmd”
def on() {
log.debug “in on”
delayBetween([zwave.basicV1.basicSet(value: 0xFF).format(), zwave.switchMultilevelV1.switchMultilevelGet().format()], 1000)
def off() {
log.debug “in off”
delayBetween ([zwave.basicV1.basicSet(value: 0x00).format(), zwave.switchMultilevelV1.switchMultilevelGet().format()], 3000)
def setLevel(value) {
def valueaux = value as Integer
def level = Math.max(Math.min(valueaux, 99), 0)
log.debug “in set level new level = $level”
if (level > 0) {
sendEvent(name: “switch”, value: “on”)
} else {
sendEvent(name: “switch”, value: “off”)
//sendEvent(name:“switch.setLevel”,value:level)
delayBetween ([zwave.basicV1.basicSet(value: level).format(), zwave.switchMultilevelV1.switchMultilevelGet().format()], 500)
def setLevelo(value) {
def level = Math.min(valueaux, 99)
log.debug "in set level new level = $level"
delayBetween ([zwave.basicV1.basicSet(value: level).format(), zwave.switchMultilevelV1.switchMultilevelGet().format(),
			 	sendEvent(name:"switch.setLevel",value:level)], 500)
def setLevel(value, duration) {
log.debug “in set level w duration new level = $value duration = $duration”
log.debug “in set level w duration new level = $level duration = $duration”
def dimmingDuration = duration < 128 ? duration : 128 + Math.round(duration / 60)
zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: dimmingDuration).format()
def poll() {
initialize()
def refresh()
{ log.debug “in refresh”
// invertSwitch()
def indicatorWhenOn() {
sendEvent(name: “indicatorStatus”, value: “when on”, display: false)
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 3, size: 1).format()
def indicatorWhenOff() {
sendEvent(name: “indicatorStatus”, value: “when off”, display: false)
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 3, size: 1).format()
def indicatorNever() {
sendEvent(name: “indicatorStatus”, value: “never”, display: false)
zwave.configurationV1.configurationSet(configurationValue: [2], parameterNumber: 3, size: 1).format()
def invertSwitch(invert=true) {
log.debug “in invert”
if (invert) {
zwave.configurationV1.configurationSet(configurationValue: [1], parameterNumber: 4, size: 1).format()
else {
log.debug “turn off invert”
zwave.configurationV1.configurationSet(configurationValue: [0], parameterNumber: 4, size: 1).format()
def setColor(value) {
log.debug “setColor: ${value}, $this”
if (value.hue) { sendEvent(name: “hue”, value: value.hue)}
if (value.saturation) { sendEvent(name: “saturation”, value: value.saturation)}
if (value.hex) { sendEvent(name: “color”, value: value.hex)}
if (value.level) { sendEvent(name: “level”, value: value.level)}
def setAdjustedColor(value) {
if (value) {
log.trace “setAdjustedColor: ${value}”
def adjusted = value + [:]
adjusted.hue = adjustOutgoingHue(value.hue)
// Needed because color picker always sends 100
adjusted.level = null
setColor(adjusted)
def adjustOutgoingHue(percent) {
def adjusted = percent
if (percent > 31) {
if (percent < 63.0) {
adjusted = percent + (7 * (percent -30 ) / 32)
else if (percent < 73.0) {
adjusted = 69 + (5 * (percent - 62) / 10)
else {
adjusted = percent + (2 * (100 - percent) / 28)
log.info “percent: $percent, adjusted: $adjusted”
adjusted
def ping()
//command(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x01)) //poll the temperature to ping
def installed() {
log.trace “Executing ‘installed’”
// use settings report time for check interval it is mintes
sendEvent(name: “checkInterval”, value: 3600 , displayed: false, data: [protocol: “zwave”, hubHardwareId: device.hub.hardwareID])
initialize()
private initialize() {
log.trace “Executing ‘initialize’”
sendEvent(name: "DeviceWatch-DeviceStatus", value: "online")
sendEvent(name: "healthStatus", value: "online")
sendEvent(name: "DeviceWatch-Enroll", value: [protocol: "cloud", scheme:"untracked"].encodeAsJson(), displayed: false)
