Hi guys,
I have a couple questions about Samsung ST Motion Sensor, Can I adjust the sensibility and coverage ?
Hi guys,
You can adjust coverage to narrow it using a tube. They don’t have sensitivity adjustments as far as pet immunity or range though on the board. For that you’d need a 3rd party sensor like EcoLink.
Placement, and white stickers can also work for honing in.
I would also add that rotating the motion sensor gives different coverage as well. Example, turning the sensor so the bump is on the right or left side, will give you a wider range left to right and narrower height.
