I just purchased the latest Nest Thermostat, specifically because it supports Matter integration. But when I try to add the device to SmartThings using the setup code generated by the Nest, it fails adding the device to SmartThings.
Commissioning begins smoothly, the process finds the device and determines it’s a Nest Thermostat. In the final step “adding the device to SmartThings through your hub” it eventually fails with the error code 39-511.
I’m not sure where to find any additional details on what’s happening. I’m running the latest software on the Nest Thermostat, and have tried everything I can think of.
Does anyone have this working? Any ideas what I might try next?
3. Where do I open a support case? I did submit a request from the app, but it didn’t provide any case information.
4. Attached is a screenshot of the final screen once it times out. I can make a series of them if you want to see all of the screens, but it takes several minutes for it to actually timeout.
5. I submit the logs, which should contain my attempts to pair with the thermostat.
Hi, @ChristopherH
I see you have more than 1 hub, can you let me know the name of the one where you tried to discover the device to get its ID for the report, please?
Also, the screenshot you took was at 10:48 am, and you’re using Pacific Time, correct?
Hi, @ChristopherH
The engineering team checked the hub logs, and they noticed they present the same error as the known issue with Nest devices.
The Hub firmware version 60 should help with this (which is currently available for the Beta Group), so the suggestion is to install this version in your hub to see if it helps.
We can add your hub manually to receive only this version, but we need your authorization if that’s what you want.
You can also wait for the Customer release, but there’s no ETA yet.
Hi, @ChristopherH
The engineering team added you to the list to receive this last beta firmware. This won’t add you to the Beta Group completely, you’ll receive the Beta update only this time.
The next time the Hub “checks in” with the platform, it will be updated. You can speed up the process if you reboot it.
Hi, @ChristopherH
The engineering team told me that if you wish to continue being part of the Beta Group to receive the firmware updates beforehand, you should enroll directly as mentioned here:
I got my Nest Learning Thermostat 4th gen with Matter and I get the same issue as well. When is this new firmware coming for general availability for everyone?
