Adding Fibaro
Evening folks,
I’m moving into a new house and plan to instal 10/15 Fibaro relays and dimmers.
I did a test run and realised that the switch needs to be really close to the hub… not necessarily easy without a mega long Ethernet.
So my question is, can I add a new thing without the hub being connected to the internet?
Many thanks,
Nick
Some people have just connected up the neutral and live to the Fibaro unit on a flying lead that you can plug into a socket near your hub. Then pair it with the hub and properly install in the position you want it.
the answer is No :slight_smile:
Thanks Robin!
