Adding devices network ID (Nest)
Hi Community!
Would anyone be able to assist on how I find a network ID for a device? I am trying to integrate my Nest Thermostat.
For my Tado I just put in Tado Thermostat.
Are you using Nest Manager?
http://thingsthataresmart.wiki/index.php?title=Nest_Manager
As said above, I have a Tado.
In the ID field that you are after, that is what I put in.
Give it a try.
It won’t do any harm and if it’s no good, just delete the device and try again.
For the Tado I use the Tado (Connect) smartapp.
awesome thanks. now that i have it added, using nest manager, it is only showing 0 degrees and i can’t control it(it still work manually). any ideas?
Ensure you followed all the installation instructions in the link above.
You should look at IDE logs and share them in a private message with tony or myself.
http://thingsthataresmart.wiki/index.php?title=Nest_Manager#Troubleshooting
figured it out… i didnt install the nest thermostat from nest.com. got that done and now its working!
thanks again!
