Added Door State to Matter lock driver
Successfully running off of your driver with the ultraloq matter fingerprint door lock now. There are some quirks with deleting the device and re-adding it using your driver, and the user list being empty but it says the codes are still in use. I also found this to be true with the stock SmartThings matter door lock driver. To remedy I had to log into the advanced smart things web site and go into the device card and in the commands section I had to delete all credentials and delete all users before deleting the device, then re-adding it with your driver. From there I could set all of my codes. At least I found that work around for now until it is fixed. But the main point is your driver is working by showing the doorstate and manage user on the device card in smartthings. Thank you very much!
Cool!
:smiling_face_with_tear:
