Hi, I have a Schlage, Z-Wave door lock on a rental garage and I want to give a tenant access to this garage via the lock on specific days and times. Can someone suggest an app or something that is easy to use and program?
rdecaro2:
Look at this post:
We searched for a viable solution for a long time and decided to finally build our own: Rental Home Automator . We wanted to keep it simple & affordable, and the best way for us to do that was to integrate directly with SmartThings. We can do everything described in this thread, as we were looking for the exact same functionality that many of you are (or were) looking for. Check out why we think it’s the ideal RBoy Apps replacement , and feel free to use the discount code GROOVY40 for a discount for people on this forum.
and this one:
Sorry you got sent in the wrong direction.
There is no native ST capability for time based user lock codes and Rboy has not released a replacement for LUM in the new architecture. No-one has created another ST app that can do time based codes either.
Some people are using other third party solutions that support time based codes like Seam or lockmanager.io . Others are using Sharptools to add and delete codes at specific times to emulate the behavior formerly in LUM. @bthrock is using an app that is supported on the Hubitat platform and an Edge driver that can uses the ST APIs to synchronize devices between the two platforms (requires s Hubitat hub).
That’s the current state, unfortunately.
No really good solutions still at this time. As Matter based locks start coming on the market, there could be locks that support schedules natively since it’s built into the Matter lock specs.
