Hi all.
So i have a minor issue that I am looking for a fix for. My blind motors are Aqara so i have a virtual switch in ST, reflected in actiontiles, so I can open and shut a group of blinds from the panels.
Problem is that the blinds are also on routines. So Actiontiles does not update the change in status of the blinds once the routine has run. ie panel still says blinds closed when they are open. This then means a double tap on the tile to open/shut blinds manually.
Any ideas as to how I can get Actiontiles to change the virtual switch status based on the routine?
Thanks in advance
