Account locked after Samsung account country change IT to AR — SSO callback returns 500, country change already completed
My SmartThings account has been completely inaccessible since a Samsung
account country change from Italy to Argentina, requested on 2026-08-22.
WHAT I HAVE VERIFIED
  1. The Samsung account country change is COMPLETE. My profile at
    account.samsung.com/dashboard/profile displays “Argentina” with no
    pending request and no processing notice.
  2. The SmartThings mobile app still displays the block: “Your Samsung
    account country information was changed. While your request is being
    processed you will not be able to use SmartThings.”
  3. Signing in at account.smartthings.com fails with an unhandled server
    error at the SSO callback. Samsung’s side returns a valid auth code
    (visible in the callback URL), then SmartThings throws:
    Reference ID: b69d26d1-4e12-37c9-51e7-7e2b47909235
    Error Time: 2026/08/23 19:51:14
  4. Clearing app cache and data, and signing out and back into the Samsung
    account on the device, changed nothing. The failure is server-side.
  5. I emailed support@smartthings.com as instructed by that very error
    page. It bounced with an automated reply stating the address is no
    longer monitored, redirecting me to the US Samsung contact page.
MY READING OF THE PROBLEM
This is not a pending migration. The Samsung account side has already
completed. A 500 on identity resolution indicates the account record is
in an inconsistent state — most likely still registered to the EU shard
while the account now routes to the Americas region.
I understand from previous threads here that the shard is assigned at
account creation and is not migratable. If that is the case, please say
so plainly so I can act.
WHAT I AM ASKING FOR
Either:
(a) correction of the region/shard registration for this account, or
(b) if cross-region migration is not technically possible, deletion of
the SmartThings registration for this account so it can be
recreated in the AR region and I can re-onboard my devices.
Either outcome works for me. Indefinite lockout does not.
ON DATA RESIDENCY
My account originated in Italy (EEA). If EU data residency is the
blocker, I explicitly consent to the erasure of my SmartThings data held
in the EU region in order to complete this transition. I am prepared to
file a formal GDPR Article 17 erasure request if that is the required
route, but I would much rather resolve this through support.
Samsung account: julianmarmol@gmail.com
Happy to provide any further Reference IDs — I am collecting a new one
daily to document that this is persistent, not transient.
ST staff are not actively monitoring this community support for the most part. Your best option is to reach out to Samsung support. Since you can’t login to the app, you should go to Samsung’s website and at the bottom of the page, tap on Support home to find what contact methods are available to you. I would not be surprised if a reset of the hub will be required but don’t do it unless Support tells you to.
