The post was to theorize and to get the communities opinion on the matter. “Could” it be done?
Hell, I only have 3 Abode contact sensors and none of which are tied to ST ( to keep HA and security separate). I still need to get the remaining 8 Abode contact sensors.
I figured, doing it this way (virtually), Im really not tying the security side directly into HA, since the sensors will only be directly connected to the Abode hub. Is my logic correct?
When I logged into IFTTT from my desktop and started creating a new Applet, I chose Abode for the “IF” (door opened) and Maker for the “THEN”, and was greeted with that lil guy!
I know, was just joking with you…The easier one is the outgoing synchronization But incoming synchronization is not that bad once you get your dash link
Guess Ill need to get my phone and get into CoRE and see whats up with the IFTTT Maker integration.
If I can do it without creating virtual devices as stated here: [quote=“JDRoberts, post:13, topic:65426”]
That’s why you don’t need the virtual switch
[/quote]
I think I can accomplish what I want.
I truly believe my brain is over complicating this for me.
Well you do need to sit down and take your time setting up the first one. The first one will be tricky. But once you get it, the rest of them will be smooth sailing.
The easy way, where you just call the action “windowsOpen” only works in the “If” portion of IFTTT.
Since the Abode devices arent in ST, I’ll either have to do this the hard way (screenshot above) or make virtual devices for each window/door and tie them to Abode via IFTTT first.
I don’t know what the hard way needs. Im not a programmer and dont know “post, get, etc” or whats needed in the “body” section…
Using this example, replacing dashboard with /ifttt/WindowsOpen, what type of method would I use? POST?
What is the content type? JSON?
What would go in the body?
For my “windows open, hvac off” piston, Id have to essentially make it 2 pistons. One for when any window opens, and another when all windows closed, following the same idea as above with the /ifttt/WindowsClosed
Just doing a sanity check. The post linked by @SBDOBRESCU is a bit confusing when it calls for “ingredients of the if event into the Maker request body, CoRE can import those into variables.”
If Abode door sensor is opened
Then (My URL with event name)
Piston in Core:
If EventName via IFTTT
Then turn on bloom and set color.
IT WORKED!
Now that I understand what the screenshot above needs, this should be rather simple. I just have to get the remaining Abode sensors and I ‘should’ be set! Itll take me a while to recreate my pistons using this method, but isnt impossible.
WAF will skyrocket because of only needing one sensor on the doors and windows and lower cost to operate (less batteries)!
Hey @Turb02 thanks for challenging me yesterday I now have a door chime, a notification with colored bulbs and autolock at 60 min for my front door, all within one Piston… @ady624 's CoRE rocks!
