@Paul_Sheldon, Can you modify ABC to works with “Smart Switches” that are actually buttons. For example “Sengled Smart Light Switch” its actually zigbee remote with 4 buttons, however Smartthings adds it as a dimmer switch, and ABC doesn’t show it at all.
When you have time could you please modify it so you can set the dimmer values to ‘0’ ZERO please. At the moment the app will not accept ‘0’ it states that no value has been set.
Hi, thanks for the quick reply.
I’m using a Devolo switch controlling a CUSTOM Blinds DH.
I did not try before but it seems to accept the zero value but will just not display it. It states ‘Missing’ (see attached) but it does actually dim or in this case close the blinds to the zero value. So not as big an issue for me but would great if this can be fixed at some stage to actually show the zero value as opposed to 'Missing" but I’m not sure if this is connected to your SmartApps or if it is showing this as its getting out from elsewhere.
Could you also let me know the model number of you switch and a copy of the DH or link to it please. This will allow m to add the switch info to ABC so you get images when programming the buttons.
You need to set the DTH to send button numbers to ABC, the DTH https://github.com/paulsheldon which will give you the option in the app setting for the deice to send button numbers.
If you login to the smartthings IDE and look at Live Logging you will see info about what button was pressed in the Mapping file associated to that device
If you have not got the button numbers set you will see lines like
22:40:52: debug Office Dimmer: Button on was pressed
This is incorrect as it should say Button 1 not Button On.
You can always send me a copy of the live log and I’ll take a look for you
Cool. I’m in bed now. I’ve got your updated DTH and app downloaded. I’ll try to switch one of the lights over to yours in the morning and report back.
I did try it before I came to bed and it was turning on but not off so I reverted it back to webCoRe and the old DTH.
Then I realised it wasn’t turning off as I hadn’t set the off action. In my defence I am tired LOL.
Edit - I just swapped one of them to your app and it’s now all working. Hopefully I get no drop outs. Will let you know how it is in the morning.
Thanks for this. Wish I’d found it earlier before I hacked the old DTH to work for me and spent hours trawling the logs to figure out the events to use in webCoRe LOL. Good work
quick question, I have GitHub connected for your SmartApps, however for the DTHs I get an error just saying that the download/update has been skipped due to errors, any ideas on that?
Hi @Paul_Sheldon, just a quick question… Is there any way to copy our controls to make duplicating them easier? I have a room with 3 zooz switches I’m using for scenes and I’d like them to function identically, but it takes about 10 min to set up each switch. Hoping I can just copy the first and change the switch name… I also have about 5 other rooms I’d like to set up very similarly, so being able to duplicate existing setups would really be nice.
Also, another question: ABC registers a hold on my Zooz (Zen27) switches, but I can’t get webcore to see holds, just pushes. Any insight into why that might be?
