64 bit source address of Xiaomi's Aqara Zigbee sensors changed to FF FF FF FF FF FF FF FF
I have one coordinator, router and few xioami zigbee sensor devices.The Aqara sensor’s parent is router and data is received at the coordinator via this router. Initially 64 bit source address in the data received from the sensor was
00 15 8D 00 02 B8 4D AA
But after turning power Off and On of coordinator, the 64 bit source address in the data received changed to
Zigbee Sensor Data before power off was as follows.
Explicit RX Indicator (API 1)
7E 00 19 91 00 15 8D 00 02 B8 4D AA BF 50 01 01 00 06 01 04 00 18 10 0A 00 00 10 00 BD
Start delimiter: 7E
Length: 00 19 (25)
Frame type: 91 (Explicit RX Indicator)
64-bit source address: 00 15 8D 00 02 B8 4D AA
16-bit source address: BF 50
Source endpoint: 01
Destination endpoint: 01
Cluster ID: 00 06
Profile ID: 01 04
Receive options: 00
RF data: 18 10 0A 00 00 10 00
Checksum: BD
After Power Off and On at coordinator
  7E 00 19 91 FF FF FF FF FF FF FF FF BF 50 01 01 00 06 01 04 00 18 16 0A 00 00 10 00 12
        Start delimiter: 7E
        Length: 00 19 (25)
        64-bit source address: FF FF FF FF FF FF FF FF
        16-bit source : BF 50
        Source endpoint: 01
        Cluster ID: 00 06
        Profile ID: 01 04
        Receive options: 00
        RF data: 18 16 0A 00 00 10 00
        Checksum: 12
Why 64 bit source address changed?
I am facing the same issue. Please somebody help me out
Hey jinujosefrancis, is the coordinator you are using a SmartThings hub? Can you also share what the router device is?
The coordinator and router is xbee s2c module.
Hey @jinujosefrancis,
These forums are meant to focus primarily on the SmartThings products/ecosystem. For help with the XBee module I recommend contacting Digi customer support.
I didn’t received Digi support , That why i contacted this forum.
If you know anything about it ,Please reply me .Thank you.
