Anyone know of a 40amp switch that is a plug in? All of the ones I have seen are direct wire or 15amp certified. I want to plug in my oven and not rewire. Prefer zwave but not a requirement.
Unfortunately, the only two I know of require rewiring.
There’s a big box one from Jasco/GE which is intended for outdoor use, like with a pool pump. It does have a manual button override, which is a nice feature, but it’s still a big box (11.5" tall).
http://www.ezzwave.com/direct-wire-indoor-outdoor-smart-switch
And there’s an in wall relay from Aeon:
http://www.amazon.com/Aeon-Labs-White-V3-26-AL001/dp/B00MBIRF5W
Both would require wiring, though. Not that complicated wiring, about the equivalent of replacing a wall receptacle. Most electricians should be able to do it pretty quickly.
If you do decide to go with one of those, shop around, as prices vary a lot. ( there are also a couple of contractor boxes, but those are even bigger than the Jasco.)
Also, Are you sure the stove is only 40 A? A lot of them are 50.
You are right. It’s 50… Guess I will just put a temp sensor to know its on and not worry about trying to switch off remotely. Bummer.
