Can someone tell me what I’m doing wrong? I’m sure it’s user error.
I have 2 DHs that need updating…webcore, and Ecobee Suite. When update from repo and commit changes, I get a 404 ERROR: Not found. What am I doing wrong? How can I fix this? Simple words please.
Try using incognito (private browsing) window and see if the error goes away. Sometimes the ide has issues with old cookies.
Yep tried that. No luck
you login to IDE at https://account.smartthings.com ?
You will probably need to disconnect your github account and reconnect it. To do so, click on the settings tab which is next to the update from repo tab. Take a screenshot of your github repositories first, disconnect your account and reconnect.
OR contact ST support at https://support.smartthings.com
That worked! Thanks so much.
