Any bundle of wires behind the switches and measurements? Your measurements are great but here’s an example of the info most useful for online help. Obviously sometime it could not be done this way. Just a simple picture with all the wiring.
Ok guys.
I need some help.
I have a great Room fan and light that are each on a 3 way circuit.
I have no idea how to wire this up right
The main wal box is 3 gang. Call it Wall Box A
It has fan, fan light and mud room light
A while back I swapped out mudroom for a GE switch and aux on a 3 way
Wall box B, 2 gang, contains the companion 3 way switches for both the fan and fan light
Wall box C is basically irrelevant to the discussion but I’m including it for the sake of diagraming ALL wiring related to Wall Box A. Wall box C, 1 gang, contains the GE Switch associated with the Aux switch in Wall Box A.
All I want is to wire up the Fan (not the fan light) on a Zwave fan controller. I have a GE Fan control switch and a GE Aux switch.
Here is a wiring diagram of the switches and all w…
