SmartThings Community
3A Nue RGBW strip controller with normal RGBW led strip lights: Manufacturer’s DTH
dth_lighting
project_lighting
(JOEY ESTRELLA) #21
Yes I got it! well done …Thank you very muchSir! for all your hard work on this, it’s greatly appreciated.
(Larry) #22
Hi and thanks for your work on this device handler. I’m hoping you could sent me thr code, I’m getting the following error when copy and pasting into the create new handler window.
xOrg.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script_dth_metadata_f3735cda_4a9b_4a27_91b6_86f00a0c43c1: 14: unexpected token: NUE @ line 14, column 23. definition (name: “3A NUE ZigBee RGBW Light”, namespace: “smartthings”, author: “Kevin X- 3A Smart Home”) { ^ 1 error
larryslutzky@gmail.com
#23
Hi Larry,
Please have a look the attached file for the script.
Regards,
Kevin
(Larry) #24
Hi Kevin, Not seeing attachment , can you send again.
THanks
#25
lslutzky https://community.smartthings.com/u/lslutzky Larry
July 19
THanks
Visit Topic
https://community.smartthings.com/t/using-smartthings-hub-support-3a-nue-rgbw-strip-controller-with-normal-rgbw-led-strip-lights/127648/24
or reply to this email to respond.
In Reply To
3asmarthome https://community.smartthings.com/u/3asmarthome
July 19
Hi Larry, Please have a look the attached file for the script. Regards,
Kevin
Visit Topic
To unsubscribe from these emails, click here
https://community.smartthings.com/email/unsubscribe/73fc99d00b6c39d1a0aa980a2f55c9c2c271920687e620a91b07a3ea55eee3dd
#26
Please tell me your email address for it.
(Larry) #27
#28
I receive this message pasting code
#29
Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script_dth_metadata_46425448_9765_4b1b_a160_f7ba7511ec2f: 14: unexpected token: NUE @ line 14, column 23. definition (name: “3A NUE ZigBee RGBW Light”, namespace: “smartthings”, author: “Kevin X- 3A Smart Home”) { ^ 1 error
#30
Please tell me your email address so that I can email it to you.
(David Efaw) #33
littleninemile@gmail.com
#34
Still need update by email please- littleninemile@gmail.com
(Larry) #35
Hi Kevin,
I’ve installed the device handler and Smarthings hub has found the switch as “Thing” but no controls are available…
Any advice on getting it running?
Thanks,
Larry
Thing Device
Name
Thing
Label
Type
Unknown
Version
Published
Zigbee Id
00124B0018541F5E
Device Network Id
E130
Status
ACTIVE
Hub
Bent Tree Hub
Last Activity At
2018-07-26 1:32 AM EDT
Date Created
Last Updated
Data
  • model:
  • application:
  • manufacturer:
  • endpointId: 0D
    Raw Description
    0D C05E E15E 02 01 1000 01 1000
    Firmware
    Check Now
    Current States
    No states found
    Execution Location
    Cloud
    Events
    List Events
    In Use By
#36
Hi Larry,
  1. Please tell me your email so that i can send you the device handler .
  2. Edit the device “Thing” from API
    – Name : 3A Strip Light
    – Type: 3A Nue ZigBee RGBW Light
    – Version: Self-Published
  3. Go back your mobile phone and open the SmartThings APP to control the smart 3A Strip Light. The initiate default setting is to turn ON the W (white channel) only. If you are using a RGB strip light or some brand of RGBW strip lights, you will not see the lights ON as you click the ON /OFF button until you click the strip light name and open the colour selection panel and choose a colour. Then the ON /OFF button will work normally.
(Larry) #37
Great, its working…Thanks
(Derek Jones) #38
3asmarthome,
Do you have a link to this script on GitHub?
Thank you.
#39
Sorry, not yet so far. I can directly email it to you if you need it.
(Michael Duncan) #41
Hi, I’m unable to get the code to work from the community post either. Do you mind sending a copy to me? Thanks!
EMail:
mike@murphync.net
(Larry) #42
Ok, so the controller is taking commands directly from the smarthings app, but not from Smart lighting automation. I have an automation set up that turns on lights when motion is detected, the other lights in the group turn on, but not the 3A NUE RGBW Lights.
Any ideas?
#43
It looks like something wrong with your automation setting. It should not have any difference in controlling it from the APP or SmartThings Automation.
