So I have outside lights that work on a 3 way light switch. I’ve done a little research and came to a conclusion that the GE Toggle Switch with the AddOn probably wouldn’t work since it seems to just allow you to create a 3 way switch from a non 3 way switch.
Are there toggle switches in which I can just replace my current two 3 way switches that would work with smartthings? The easiest would just switch out the new switch putting the wires in the same location on the new switch.
Thanks for your help.
Ryan
