In a 1-way switch (not sure what to call “regular, not 3-way or 4-way”), though, you expect a switch to be in a certain position when it’s off and a different position when it’s on. Since a smart switch can be turned on and off (and dim level set) from other than manual flipping, you’d lose that positional feedback.
I think having the physical switch in a “neutral” position is best. But this is just opinion, of course.
If you’re mixing smart and dumb switches in a multi-gang box, the smart switch(as) do look odd.
Agree with this. ‘Normal’ 3-way switches are already different because ‘on’ may be up or down and visa versa depending on what switch was used the most recently. To me, that smart switches return to the middle position is a non-factor and actually makes more sense than the constantly changing ‘normal’ 3-way switch appearance.
I still use these switches for 3 way… are they not ST compatible anymore? I don’t recall using a custom DTH. I think the only quirk was the LED indicator setting for the device behaves opposite of what is described.
ge Zwave plus/ homeseer zwave plus and maybe any zwave plus switch now supports direct association, so if you want to go with zwave plus, can use 2 zwave plus switches, one controls load, one is only for switching the switch connected to load.
The small led on the units will still be out of sync.
Regular is a non smart switch, it is either up or down (on or off). With regular switches you loss the position anyway unless you are supper anal… I know people that way!
I agree, mix is odd looking.
Thanks for the tip. When we last checked with the ST team (a couple of months ago when talking about certification), they couldn’t tell us when the OTA function for Z-Wave would be enabled and didn’t offer to accept the files anyway but we’ll check again!
