I’m new to the automation world and I have a Zipato RGBW Bulb. My knowledge of Z-Wave is very limited but I’m learning as I go. My main goal (as of right now) is to make this light turn any color other than white!
I’m trying to create a Device Type and running into a few problems.
First: I question whether or not “capability.colorControl” actually works for Z-Wave Lights. I assume it only works for ZigBee.
groovy.lang.ReadOnlyPropertyException: Cannot set readonly property: payload for class: physicalgraph.zwave.commands.colorcontrolv1.StateSet
I’m sure most of my code may be wrong but if anyone could provide some insight or point me in the right direction I would greatly appreciate it. I have over a ton of web browsers open with duplicate tabs all about Z-Wave
If it helps I tried adding a fingerprint of the bulb and other combinations of the zwave command.
The device pairs to the hub and can be controlled both “On” and “Off” but no color control. I have looked through the Hue documentation but I believe they are ZigBee and this light is Z-Wave.
