I have seen code examples for sendPush(msg)
but I want to just write to the activity feed and not send a push message. How do I do this?
log.debug
nope
log.trace
nope
log.info
log.warn
log.debug
nope
log.trace
nope
log.info
log.warn
sendNotificationEvent( String )
As far as I can tell, sendNotificationEvent writes to the main activity feed, but what about to a particular deviceās activity log?
Does not work in Device Types:
12:41:14 AM: error groovy.lang.MissingMethodException: No signature of method: script1415684285914308354464.sendNotificationEvent() is applicable for argument types: (org.codehaus.groovy.runtime.GStringImpl) values: [Set Heating point to 61.0] @ line 341
c45dc2e0-2f12-48ba-89ab-2cb845a687a1 12:46:45 AM: error groovy.lang.MissingMethodException: No signature of method: script14156848054681329331708.sendNotificationEvent() is applicable for argument types: (java.lang.String) values: [Set Heating point to] @ line 341
I can confirm the same, so how does one write the activity feed for the device?
pulled this from the z-wave motion device
example 1
createEvent(name: "motion", value: "active", descriptionText: "$device.displayName detected motion")
example 2
createEvent(descriptionText: "$device.displayName: $cmd", displayed: false)
example 3
createEvent(descriptionText: "$device.displayName covering was removed", isStateChange: true)
Thank you, is this also the same way to log events from a smart app incase you know?
BTW does this post the main activity feed or the device activity feed?
Interestingly I tried all of the above and some combination but I donāt see anything reported in the main event activity log or device event activity log. I guess this doesnāt work in Smart apps.
@docwisdom were you able to figure out if you can get the log to show up in the activity?
@tslagle13, @minollo @bflorian - wondering if you guys could shed some light on how SmartApps can post to the activity log of a device?
Wondering if a smartapp can do this. They may be walled off from the activity feed. What do you see in the logs when you run a createEvent command?
Why would an app post to the activity log of a device? A device can/should do that, not the app. In my own device types, I do that using sendEvent() - or createEvent(), depending on the context where itās used.
Thatās correct. createEvent()
should be used to construct the event object returned by the parse
method. It only works from inside parse. Use sendEvent()
from other contexts, such as a command method.
Thanks @bflorian so is that the right way to send a message from a SmartApp to a device activity feed using sendEvent()?
@minollo Hereās what happening, I have a thermostat program. When it changes the temperature for a device I want it to write to the device feed that it changed the current temperature to XXX AND also write when the next temperature change is scheduled.
Apps donāt do sendEvent(); devices do.
Apps can invoke device methods freely, I believe; so, I suppose you could add an advanced version of the device setHeatingSetpoint() method, make it handle both a requested temperature change and a timestamp setting, and create an event (setEvent()) for the timestamp setting.
Of course that also implies that you need to add a custom āattributeā to your device, something like:
attribute ānextScheduledTemperatureChangeā ādateā (or āstringā, if ādateā is not supported) in the metadata/definition section.
Thatās right ā a custom command actually.
There is no way to explicitly send an event from a smart app to a deviceās activity feed. When you change the temperature you should see an event like āGood Morning sent setHeatingSetpoint command to Dining Room Thermostatā, but there is currently no way for you to customize that message or create an additional one.
If you are writing the device type as well as the smart app, you could create a custom command to generate an event with the message you want and call that command from the smart app, but that wouldnāt work with any thermostat.
I do understand your scenario and weāll take a look at how we might make these app-to-device messages more useful. The default ones are admittedly not very user-friendly in some cases.
Thanks, BTW so I write a custom device type for thermostat (which I"ve also submitted to ST for publishing, more features).
I put this statement in the setHeatingPoint function:
sendEvent(name: $device.displayName, value: āSet heating point to $degreesā)
and it errors out:
c45dc2e0-2f12-48ba-89ab-2cb845a687a1 1:23:26 PM: error java.lang.NullPointerException: Cannot get property ānameā on null object @ line 341
The same thing happens with label and name. This is on a live thermostat (not simulator) so Iām guessing thereās a bug in there which is returning null for name and label
You need to omit the $ character in the value of the name field. Itās only needed inside a string. In other words:
sendEvent(name: device.displayName, value: "Set heating point to $degrees")
However, the name of the event shouldnāt really be name of the device, it should be the name of the property. So I would do something like this:
sendEvent(name: "heatingSetpoint", value: degrees, descriptionText: "Set heating setpoint to $degrees")
