Geko this app is great, I want to thank you for creating it!
I am having the same issues as hubertsimon, I can control VLC from the smartapp but I am unable to get it to play any of the event notifications working.
The test function on the app works, it just will not trigger anything based on events.
Again thanks for making this app! This paired with some Rasp Pi’s and small speakers would give whole home audio notifications!
Ok, I see in the logs that Sonos Notify with Sound app throws an exception:
9:59:01 PM PDT: error groovy.lang.MissingPropertyException: No such property: options for class: physicalgraph.device.HubMultiAction
Possible solutions: actions @ line 272
I was able to get the AirFoil setup up and running on my windows 2012 virtual server. Very nice work @geko. Thanks for the airfoil tip @stockmopar. How much delay are you seeing?
I downloaded the airfoil speakers app for android, linux, and windows. They all work, but the android app only works when it is active and in the foreground. Still pretty cool.
The only issue I had was with VLC itself. The Windows 64-bit version has a bug that prevents it from playing https streams. Installing the 32-bit version of VLC fixed this.
@jody.albritton I was able to get it to work running in the background, the app has issues on my galaxy s5 but it’s fine on an old galaxy nexus from verizon. I’m going to try it on the nexus 7 next.
@geko thanks for your work on this app, amazing! I decided a long time ago no way I was dumping hundreds of dollars into ubi or sonos, but you’ve made it virtually cost free. Your app tied with Airfoil and the dedicated tablets I’m using with Home Automation Dashboard and Web Dashboard
Indeed, that was what I experienced. It cannot do the handshake to sync with the desktop machine unless the app is in the foreground. I have a little android mini pc and if this could run in the background it would be amazing. I already have google now and tasker running on the little box and this would have been the icing on the cake.
I have been playing with doubletwist’s magic play as well. It’s not working as advertised at this point. I have followed this thread and will post any progress I make.
I couldnt get VLC thing to work. I have VLC setup correctly on my Mac, web interface enabled, i can access it via direct IP.
The smartthing mobile side, i create the device type and new device, put IP and port to it. But none of the feature works, the web IDE log keep saying status: disconnected.
Any thoughts what might went wrong? The only thing i can think about is my smartthing hub is on 192.168.1.x, and my mac is on 192.168.0.x. will that cause this issue?
Make sure you have VLC TCP Port 8080 and then setup the password the same as VLC. I had an issue ended up not using the port i set in the config. It would always default to port 8080
