I am working to integrate smartthings into http://www.roomieremote.com. The goal is to control my lights inside the roomie app. I am about to invest in zwave dimmers and already have phillips hue. Roomie allows to run a URL commands in the background. That is the only way I’ve been able to figure out how to get it to talk to ST. I have managed to get a light to turn on and off using this method. Here is where I struggle:
Is there a way to us the ST end pointer to dim the lights instead of (on, off, toggle)
Can I create a virtual switch that I call using the end pointer, and then that virtual switch essentially dims the lights (several dimmers or zigbee light bulbs) I need to the desired levels. Kind of like creating a macro?
Is there a better way to go about this?
I am not very technical compared to some of you, I know just about enough to get me in trouble. Hope you guys can help.
Yes, but it’s more elegant to use “Hello Home” actions, which is SmartThings equivalent of scenes.
Quick update and more questions. I got the virtual switch to trigger the big switch smart app which is calling a hello home action that turns off some lights and dims others. However, I actually need to dim my lights to about 1% (or the lowest setting) currently hello home doesn’t allow anything below 10%.
I’ve tried to figure out how to get the virtual switch to essentially do this directly, but it’s just a bit over my head. Can someone please show me the code I need to insert into the virtual switch to dim a specific dimmer to a predetermined brightness when the switch turns on and turn off the dimmer when the virtual switch turns off? I would greatly appreciate it.
Here is the code for the virtual switch.
* Virtual Switch
* Copyright 2014 Juan Risso
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Virtual Switch", namespace: "juano2310", author: "Juan Risso") {
capability "Switch"
capability "Refresh"
// simulator metadata
simulator {
// UI tile definitions
tiles {
standardTile("button", "device.switch", width: 2, height: 2, canChangeIcon: true) {
state "off", label: 'Off', action: "switch.on", icon: "st.Kids.kid10", backgroundColor: "#ffffff", nextState: "on"
state "on", label: 'On', action: "switch.off", icon: "st.Kids.kid10", backgroundColor: "#FFA500", nextState: "off"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "button"
details(["button", "refresh"])
def on() {
sendEvent(name: "switch", value: "on")
def off() {
sendEvent(name: "switch", value: "off")
