So… @AaronZON came through in a big way. His code is below and seems to work well in a 1 sensor / 1 dimmer environment:
* Turn light on with motion for x minutes if it is dark based on light sensor
* Written by Aaron Herzon
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Turn light on with motion for x minutes if it is dark based on light sensor",
namespace: "AaronZON",
author: "Aaron Herzon",
description: "Turn on lights temporarily when there is motion but only if it is dark according to light sensor",
category: "Safety & Security",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
//todo: replace icon with something appropriate.
preferences {
section("Select Motion Sensor(s) you want to Use") {
input "motions", "capability.motionSensor", title: "Motion Detector", required: true, multiple: false
section("Select Dimmers you want to Use") {
input "switches", "capability.switchLevel", title: "Dimmer Switches", required: false, multiple: true
section ("Set Brightness for motion-triggered light and on time after motion stops") {
input "BrightLevelStr", "enum", title: "Motion-Sensed Level %", required: true,
options: ["100","75","50"], defaultValue: "100"
input "DelayMinStr", "enum", title: "Bright Delay After Motion Stops, minutes", required: true,
options: ["1","3","5","10","15","30","60"], defaultValue: "5"
section ("Ignore motion if light level is above this value") {
input "LightMeter", "capability.illuminanceMeasurement", title: "Light Meters", required: true, multiple: false
input "LuxSetPointStr", "enum", title: "Lux level", required: true,
options: ["50","100","200","400"], defaultValue: "50"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
log.debug "initialize()"
state.BrightLevel = BrightLevelStr as Integer
if (state.BrightLevel == 100) {
state.BrightLevel = 99
state.DelayMin = DelayMinStr as Integer
state.LuxSetPoint = LuxSetPointStr as Integer
subscribe(motions, "motion.active", handleMotionEvent)
subscribe(motions, "motion.inactive", handleEndMotionEvent)
def handleMotionEvent(evt) {
log.debug "handleMotionEvent() Motion detected . . . ."
unschedule(turnLightsOff)
if (state.lightIsOn) {
log.debug ". . . but light is already on so do nothing"
else {
def currentLux=LightMeter.currentIlluminance
if(currentLux < state.LuxSetPoint) {
switches?.setLevel(state.BrightLevel)
state.lightIsOn=true
log.debug ". . . . and it is dark so turn the lights on"
else {
log.debug ". . . .but it is light, so do nothing"
def handleEndMotionEvent(evt) {
log.debug "handleEndMotionEvent() Motion stopped . . . ."
runIn((state.DelayMin*60), turnLightsOff)
def turnLightsOff() {
log.debug "turnLightsOff()"
switches?.setLevel(0)
state.lightIsOn=false
… here are the issues I am having though:
I would like to use multiple motion sensors. When changing “false” to “true” to pickup multiple motion sensors, the app isn’t able to fire on the lights…
Same thing happens when changing the “enum” to “number” for more granular control of the various inputs - the app no long fires on the lights.
Anyone willing to take a stab at these? I’m stumped. This could be a killer app.
Thanks again to @AaronZON for starting this one!
