Does anyone know if the Honeywell 5818MNL is compatible with ST?
Thanx!
-Michael Dow
Houston, TX
Thanx!
-Michael Dow
Houston, TX
@sominus - The door sensor above is not directly compatible with SmartThings, however if you use it in conjunction with a Honeywell/Ademco/DSC Security Panel, there are a few ways to get it integrated wtih SmartThings. I’m actively using this type of Honeywell sensor with my Vista 20p panel, but other items such as an Envisalink and AlarmServer are required. Good luck!
Best,
Matt
According to SmartThings’ Compatible with SmartThings sheet, the Aeon Labs Recessed Door Sensor is supported. I myself have not used one so I cannot confirm it.
