Pushing Smartthings Events to remote syslog/TCP port?
Hello,
I’m trying to find a way to push all Smartthings events ideally from the hub to a UDP port (remote syslog) or just pass the JSON to a TCP port. For those familiar with Splunk, I Splunk my entire home network setup and would love to add Smartthings in there to get a holistic view of what’s going on in the home.
I’m presuming I need to attach a SmartApp to the location – but have no idea how to create the listeners for all events.
Here is some code for logging to thingspeak. It would be fairly simple to repurpose it for your needs. I am not sure about the UDP logging, but I know it can be done with http.
Have you had any luck with this? I am too trying to find a way to get this into Splunk. I am excited about Hub v2, I hope it gives us more options to get the logs. Since everything will be processed locally we might be able to pull it using Full Packet Capture.
I can’t believe this isn’t an option yet, this is something that the system is already doing. I have a lot of great ideas on how I can use Splunk with Smartthings.
Just got Hub v2 and would like to dump stuff to sylog/splunk as well, any word on options with V2?
For those of you interested in splunk look here
Any luck with this? I would love to see this implemented in the future.
Did this with Splunk:
