Philips Hue Groups Control App
Hey Rob,
I’m new to Smartthings and trying to get this App up and running.
I’ve created a Device Type for both the Hue Bridge and the Hue Bulb and I’ve created the new SmartApp using your code, but when I get to Bridge Connection point, the app never sees that I pressed the button on the Bridge. I just sits and sits (I waiting about 5 minutes before giving up).
Anything else I could be missing?
Thanks!
Edit: I got it working by taking the current state of the Code for the Hue (Connect) app and updating it to work properly with Groups… here is the new code:
 *  Hue Service Manager
 *  Author: SmartThings
definition(
	name: "Hue (Group)",
	namespace: "smartthings",
	author: "SmartThings",
	description: "Allows you to connect your Philips Hue lights with SmartThings and control them from your Things area or Dashboard in the SmartThings Mobile app. Adjust colors by going to the Thing detail screen for your Hue lights (tap the gear on Hue tiles).\n\nPlease update your Hue Bridge first, outside of the SmartThings app, using the Philips Hue app.",
	category: "SmartThings Labs",
	iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/hue.png",
	iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/hue@2x.png"
preferences {
	page(name:"mainPage", title:"Hue Device Setup", content:"mainPage", refreshTimeout:5)
	page(name:"bridgeDiscovery", title:"Hue Bridge Discovery", content:"bridgeDiscovery", refreshTimeout:5)
	page(name:"bridgeBtnPush", title:"Linking with your Hue", content:"bridgeLinking", refreshTimeout:5)
	page(name:"bulbDiscovery", title:"Hue Device Setup", content:"bulbDiscovery", refreshTimeout:5)
def mainPage() {
	if(canInstallLabs()) {
		def bridges = bridgesDiscovered()
		if (state.username && bridges) {
			return bulbDiscovery()
		} else {
			return bridgeDiscovery()
	else
		def upgradeNeeded = """To use SmartThings Labs, your Hub should be completely up to date.
To update your Hub, access Location Settings in the Main Menu (tap the gear next to your location name), select your Hub, and choose "Update Hub"."""
		return dynamicPage(name:"bridgeDiscovery", title:"Upgrade needed!", nextPage:"", install:false, uninstall: true) {
			section("Upgrade") {
				paragraph "$upgradeNeeded"
def bridgeDiscovery(params=[:])
	int bridgeRefreshCount = !state.bridgeRefreshCount ? 0 : state.bridgeRefreshCount as int
	state.bridgeRefreshCount = bridgeRefreshCount + 1
	def refreshInterval = 3
	def options = bridges ?: []
	def numFound = options.size() ?: 0
	if(!state.subscribe) {
		subscribe(location, null, locationHandler, [filterEvents:false])
		state.subscribe = true
	//bridge discovery request every 15 //25 seconds
	if((bridgeRefreshCount % 5) == 0) {
		discoverBridges()
	//setup.xml request every 3 seconds except on discoveries
	if(((bridgeRefreshCount % 1) == 0) && ((bridgeRefreshCount % 5) != 0)) {
		verifyHueBridges()
	return dynamicPage(name:"bridgeDiscovery", title:"Discovery Started!", nextPage:"bridgeBtnPush", refreshInterval:refreshInterval, uninstall: true) {
		section("Please wait while we discover your Hue Bridge. Discovery can take five minutes or more, so sit back and relax! Select your device below once discovered.") {
			input "selectedHue", "enum", required:false, title:"Select Hue Bridge (${numFound} found)", multiple:false, options:options
def bridgeLinking()
	int linkRefreshcount = !state.linkRefreshcount ? 0 : state.linkRefreshcount as int
	state.linkRefreshcount = linkRefreshcount + 1
	def nextPage = ""
	def title = "Linking with your Hue"
	def paragraphText = "Press the button on your Hue Bridge to setup a link."
	if (state.username) { //if discovery worked
		nextPage = "bulbDiscovery"
		title = "Success! - click 'Next'"
		paragraphText = "Linking to your hub was a success! Please click 'Next'!"
	if((linkRefreshcount % 2) == 0 && !state.username) {
		sendDeveloperReq()
	return dynamicPage(name:"bridgeBtnPush", title:title, nextPage:nextPage, refreshInterval:refreshInterval) {
		section("Button Press") {
			paragraph """${paragraphText}"""
def bulbDiscovery()
	int bulbRefreshCount = !state.bulbRefreshCount ? 0 : state.bulbRefreshCount as int
	state.bulbRefreshCount = bulbRefreshCount + 1
	def options = bulbsDiscovered() ?: []
	if((bulbRefreshCount % 3) == 0) {
		discoverHueBulbs()
	return dynamicPage(name:"bulbDiscovery", title:"Group Discovery Started!", nextPage:"", refreshInterval:refreshInterval, install:true, uninstall: true) {
		section("Please wait while we discover your Hue Groups. Discovery can take five minutes or more, so sit back and relax! Select your device below once discovered.") {
			input "selectedBulbs", "enum", required:false, title:"Select Hue Groups (${numFound} found)", multiple:true, options:options
		section {
			def title = bridgeDni ? "Hue bridge (${bridgeHostname})" : "Find bridges"
			href "bridgeDiscovery", title: title, description: "", state: selectedHue ? "complete" : "incomplete", params: [override: true]
private discoverBridges()
	sendHubCommand(new physicalgraph.device.HubAction("lan discovery urn:schemas-upnp-org:device:basic:1", physicalgraph.device.Protocol.LAN))
private sendDeveloperReq()
	def token = app.id
	sendHubCommand(new physicalgraph.device.HubAction([
		method: "POST",
		path: "/api",
		headers: [
			HOST: bridgeHostnameAndPort
		body: [devicetype: "$token-0", username: "$token-0"]], bridgeDni))
private discoverHueBulbs()
		method: "GET",
		path: "/api/${state.username}/groups",
		headers: [
		]], bridgeDni))
private verifyHueBridge(String deviceNetworkId) {
	log.trace "verifyHueBridge($deviceNetworkId)"
		method: "GET",
		path: "/description.xml",
		headers: [
			HOST: ipAddressFromDni(deviceNetworkId)
		]], deviceNetworkId))
private verifyHueBridges() {
	def devices = getHueBridges().findAll { it?.value?.verified != true }
	//log.debug "UNVERIFIED BRIDGES!: $devices"
	devices.each {
		verifyHueBridge((it?.value?.ip + ":" + it?.value?.port))
Map bridgesDiscovered() {
	def vbridges = getVerifiedHueBridges()
	def map = [:]
	vbridges.each {
		def value = "${it.value.name}"
		def key = it.value.ip + ":" + it.value.port
		map["${key}"] = value
	map
Map bulbsDiscovered() {
	def bulbs =  getHueBulbs()
	def map = [:]
	if (bulbs instanceof java.util.Map) {
		bulbs.each {
			def value = "${it?.value?.name}"
			def key = app.id +"/"+ it?.value?.id
	} else { //backwards compatable
		bulbs.each {
			def value = "${it?.name}"
			def key = app.id +"/"+ it?.id
	map
def getHueBulbs()
	state.bulbs = state.bulbs ?: [:]
def getHueBridges()
	state.bridges = state.bridges ?: [:]
def getVerifiedHueBridges()
	getHueBridges().findAll{ it?.value?.verified == true }
def installed() {
	log.trace "Installed with settings: ${settings}"
	initialize()
	runIn(900, "doDeviceSync" , [overwrite: false]) //setup ip:port syncing every 15 minutes
def updated() {
	log.trace "Updated with settings: ${settings}"
	unsubscribe()
	initialize()
def initialize() {
	// remove location subscription aftwards
	log.debug "INITIALIZE"
	state.subscribe = false
	state.bridgeSelectedOverride = false
	if (selectedHue) {
		addBridge()
	if (selectedBulbs) {
		addBulbs()
	if (selectedHue) {
		def bridge = getChildDevice(selectedHue)
		subscribe(bridge, "bulbList", bulbListHandler)
// Handles events to add new bulbs
def bulbListHandler(evt) {
	def bulbs = [:]
	log.trace "Adding bulbs to state..."
	state.bridgeProcessedLightList = true
	evt.jsonData.each { k,v ->
		log.trace "$k: $v"
		if (v instanceof Map) {
			bulbs[k] = [id: k, name: v.name, type: v.type, hub:evt.value]
	state.bulbs = bulbs
	log.info "${bulbs.size()} bulbs found"
def addBulbs() {
	selectedBulbs.each { dni ->
		def d = getChildDevice(dni)
		if(!d) {
			def newHueBulb
				newHueBulb = bulbs.find { (app.id + "/" + it.value.id) == dni }
				if (newHueBulb?.value?.type?.equalsIgnoreCase("Dimmable light")) {
					d = addChildDevice("smartthings", "Hue Lux Bulb", dni, newHueBulb?.value.hub, ["label":newHueBulb?.value.name])
				} else {
					d = addChildDevice("smartthings", "Hue Bulb", dni, newHueBulb?.value.hub, ["label":newHueBulb?.value.name])
			} else {
				newHueBulb = bulbs.find { (app.id + "/" + it.id) == dni }
				d = addChildDevice("smartthings", "Hue Bulb", dni, newHueBulb?.hub, ["label":newHueBulb?.name])
			log.debug "created ${d.displayName} with id $dni"
			d.refresh()
		} else {
			log.debug "found ${d.displayName} with id $dni already exists, type: '$d.typeName'"
            	def newHueBulb = bulbs.find { (app.id + "/" + it.value.id) == dni }
				if (newHueBulb?.value?.type?.equalsIgnoreCase("Dimmable light") && d.typeName == "Hue Bulb") {
					d.setDeviceType("Hue Lux Bulb")
def addBridge() {
	def vbridge = vbridges.find {(it.value.ip + ":" + it.value.port) == selectedHue}
	if(vbridge) {
		def d = getChildDevice(selectedHue)
		if(!d) {
			d = addChildDevice("smartthings", "Hue Bridge", selectedHue, vbridge.value.hub, ["data":["mac": vbridge.value.mac]]) // ["preferences":["ip": vbridge.value.ip, "port":vbridge.value.port, "path":vbridge.value.ssdpPath, "term":vbridge.value.ssdpTerm]]
			log.debug "created ${d.displayName} with id ${d.deviceNetworkId}"
			sendEvent(d.deviceNetworkId, [name: "networkAddress", value: convertHexToIP(vbridge.value.ip) + ":" +  convertHexToInt(vbridge.value.port)])
			sendEvent(d.deviceNetworkId, [name: "serialNumber", value: vbridge.value.serialNumber])
		else
			log.debug "found ${d.displayName} with id $dni already exists"
def locationHandler(evt) {
	log.info "LOCATION HANDLER: $evt.description"
	def description = evt.description
	def hub = evt?.hubId
	def parsedEvent = parseEventMessage(description)
	parsedEvent << ["hub":hub]
	if (parsedEvent?.ssdpTerm?.contains("urn:schemas-upnp-org:device:basic:1"))
	{ //SSDP DISCOVERY EVENTS
		log.trace "SSDP DISCOVERY EVENTS"
		def bridges = getHueBridges()
		if (!(bridges."${parsedEvent.ssdpUSN.toString()}"))
		{ //bridge does not exist
			log.trace "Adding bridge ${parsedEvent.ssdpUSN}"
			bridges << ["${parsedEvent.ssdpUSN.toString()}":parsedEvent]
		else
		{ // update the values
			log.debug "Device was already found in state..."
			def d = bridges."${parsedEvent.ssdpUSN.toString()}"
			def host = parsedEvent.ip + ":" + parsedEvent.port
			if(d.ip != parsedEvent.ip || d.port != parsedEvent.port || host != state.hostname) {
				log.debug "Device's port or ip changed..."
				state.hostname = host
				d.ip = parsedEvent.ip
				d.port = parsedEvent.port
				d.name = "Philips hue ($bridgeHostname)"
				app.updateSetting("selectedHue", host)
				childDevices.each {
					if (it.getDeviceDataByName("mac") == parsedEvent.mac) {
						log.debug "updating dni for device ${it} with mac ${parsedEvent.mac}"
						it.setDeviceNetworkId((parsedEvent.ip + ":" + parsedEvent.port)) //could error if device with same dni already exists
	else if (parsedEvent.headers && parsedEvent.body)
	{ // HUE BRIDGE RESPONSES
		log.trace "HUE BRIDGE RESPONSES"
		def headerString = new String(parsedEvent.headers.decodeBase64())
		def bodyString = new String(parsedEvent.body.decodeBase64())
		def type = (headerString =~ /Content-type:.*/) ? (headerString =~ /Content-type:.*/)[0] : null
		def body
		if (type?.contains("xml"))
		{ // description.xml response (application/xml)
			body = new XmlSlurper().parseText(bodyString)
			if (body?.device?.modelName?.text().startsWith("Philips hue bridge"))
				def bridge = bridges.find {it?.key?.contains(body?.device?.UDN?.text())}
				if (bridge)
					bridge.value << [name:body?.device?.friendlyName?.text(), serialNumber:body?.device?.serialNumber?.text(), verified: true]
				else
					log.error "/description.xml returned a bridge that didn't exist"
		else if(type?.contains("json"))
		{ //(application/json)
			body = new groovy.json.JsonSlurper().parseText(bodyString)
			if (body?.success != null)
			{ //POST /api response (application/json)
				if (body?.success?.username)
					state.username = body.success.username[0]
					state.hostname = selectedHue
			else if (body.error != null)
				//TODO: handle retries...
				log.error "ERROR: application/json ${body.error}"
			else
			{ //GET /api/${state.username}/lights response (application/json)
				if (!body?.state?.on) { //check if first time poll made it here by mistake
					log.debug "Adding bulbs to state!"
					body.each { k,v ->
						bulbs[k] = [id: k, name: v.name, hub:parsedEvent.hub]
	else {
		log.trace "NON-HUE EVENT $evt.description"
private def parseEventMessage(Map event) {
	//handles bridge attribute events
	return event
private def parseEventMessage(String description) {
	// TODO - replace with stringToMap() when it becomes available to smart apps
	if (description) {
		def pairs = description.split(",")
		def map = pairs.inject([:]) { data, pairString ->
			def pair = pairString.split(':')
			if(pair.size() > 1) {
				data[pair[0].trim()] = pair.size() > 2 ? pair[1..-1].join(':')?.trim() : pair[1]?.trim()
			} else {
				data[pair[0].trim()] = null
			return data
		return map
	else {
		return [:]
	def event = [:]
	def parts = description.split(',')
	parts.each { part ->
		part = part.trim()
		if (part.startsWith('devicetype:')) {
			def valueString = part.split(":")[1].trim()
			event.devicetype = valueString
		else if (part.startsWith('mac:')) {
			if (valueString) {
				event.mac = valueString
		else if (part.startsWith('networkAddress:')) {
			if (valueString) {
				event.ip = valueString
		else if (part.startsWith('deviceAddress:')) {
			if (valueString) {
				event.port = valueString
		else if (part.startsWith('ssdpPath:')) {
			if (valueString) {
				event.ssdpPath = valueString
		else if (part.startsWith('ssdpUSN:')) {
			part -= "ssdpUSN:"
			def valueString = part.trim()
			if (valueString) {
				event.ssdpUSN = valueString
		else if (part.startsWith('ssdpTerm:')) {
			part -= "ssdpTerm:"
			if (valueString) {
				event.ssdpTerm = valueString
		else if (part.startsWith('headers')) {
			part -= "headers:"
			if (valueString) {
				event.headers = valueString
		else if (part.startsWith('body')) {
			part -= "body:"
			if (valueString) {
				event.body = valueString
	event
def doDeviceSync(){
	log.debug "Doing Hue Device Sync!"
	runIn(900, "doDeviceSync" , [overwrite: false]) //schedule to run again in 15 minutes
	//shrink the large bulb lists
	convertBulbListToMap()
	discoverBridges()
//CHILD DEVICE METHODS
def parse(childDevice, description) {
	if (parsedEvent.headers && parsedEvent.body) {
		log.debug "parse() - ${bodyString}"
		try {
			def body = new groovy.json.JsonSlurper().parseText(bodyString)
			if (body instanceof java.util.HashMap)
			{ //poll response
				def bulbs = getChildDevices()
				def d = bulbs.find{it.label == body.name}
				if (d) {
					if (body.state) {
						sendEvent(d.deviceNetworkId, [name: "switch", value: body.state.on ? "on" : "off"])
						sendEvent(d.deviceNetworkId, [name: "level", value: Math.round(body.state.bri * 100 / 255)])
						sendEvent(d.deviceNetworkId, [name: "saturation", value: Math.round(body.state.sat * 100 / 255)])
						sendEvent(d.deviceNetworkId, [name: "hue", value: Math.min(Math.round(body.state.hue * 100 / 65535), 65535)])
					else {
						log.warn "BODY DOES NOT CONTAIN STATE PROPERTY"
			else { //put response
				body.each { payload ->
					log.debug $payload
					if (payload?.success) {
						def childDeviceNetworkId = app.id + "/"
						def eventType
						body?.success[0].each { k, v ->
							childDeviceNetworkId += k.split("/")[2]
							eventType = k.split("/")[4]
							log.debug "eventType: $eventType"
							switch (eventType) {
								case "on":
									sendEvent(childDeviceNetworkId, [name: "switch", value: (v == true) ? "on" : "off"])
									break
								case "bri":
									sendEvent(childDeviceNetworkId, [name: "level", value: Math.round(v * 100 / 255)])
									break
								case "sat":
									sendEvent(childDeviceNetworkId, [name: "saturation", value: Math.round(v * 100 / 255)])
									break
								case "hue":
									sendEvent(childDeviceNetworkId, [name: "hue", value: Math.min(Math.round(v * 100 / 65535), 65535)])
									break
					} else if (payload.error) {
						log.debug "JSON error - ${body?.error}"
		catch (Exception ex) {
			log.error "Parse error $ex"
	} else {
		log.debug "parse - got something other than headers,body..."
		return []
def on(childDevice) {
	log.debug "Executing 'on'"
	put("groups/${getId(childDevice)}/action", [on: true])
def off(childDevice) {
	log.debug "Executing 'off'"
	put("groups/${getId(childDevice)}/action", [on: false])
def poll(childDevice) {
	log.debug "Executing 'poll'"
	get("groups/${getId(childDevice)}")
def setLevel(childDevice, percent) {
	log.debug "Executing 'setLevel'"
	def level = Math.min(Math.round(percent * 255 / 100), 255)
	put("groups/${getId(childDevice)}/action", [bri: level, on: percent > 0])
def setSaturation(childDevice, percent) {
	log.debug "Executing 'setSaturation($percent)'"
	put("groups/${getId(childDevice)}/action", [sat: level])
def setHue(childDevice, percent) {
	log.debug "Executing 'setHue($percent)'"
	def level =	Math.min(Math.round(percent * 65535 / 100), 65535)
	put("groups/${getId(childDevice)}/action", [hue: level])
def setColor(childDevice, color) {
	log.debug "Executing 'setColor($color)'"
	def hue =	Math.min(Math.round(color.hue * 65535 / 100), 65535)
	def sat = Math.min(Math.round(color.saturation * 255 / 100), 255)
	def value = [sat: sat, hue: hue]
	if (color.level != null) {
		value.bri = Math.min(Math.round(color.level * 255 / 100), 255)
		value.on = value.bri > 0
	if (color.switch) {
		value.on = color.switch == "on"
	log.debug "sending command $value"
	put("groups/${getId(childDevice)}/action", value)
def refresh() {
	log.debug "Executing 'refresh'"
	poll()
def nextLevel() {
	def level = device.latestValue("level") as Integer ?: 0
	if (level < 100) {
		level = Math.min(25 * (Math.round(level / 25) + 1), 100) as Integer
	else {
		level = 25
	setLevel(level)
private getId(childDevice) {
	if (childDevice.device?.deviceNetworkId?.startsWith("HUE")) {
		return childDevice.device?.deviceNetworkId[3..-1]
	else {
		return childDevice.device?.deviceNetworkId.split("/")[-1]
private get(path) {
	log.trace "get($path)"
	def uri = "/api/${state.username}/$path"
		method: "GET",
		path: uri,
		headers: [
		]], bridgeDni))
private put(path, body) {
	def bodyJSON = new groovy.json.JsonBuilder(body).toString()
	def length = bodyJSON.getBytes().size().toString()
	log.debug "PUT:  $uri"
	log.debug "BODY: ${bodyJSON}"
		method: "PUT",
		path: uri,
		headers: [
		body: body], bridgeDni))
private Integer convertHexToInt(hex) {
	Integer.parseInt(hex,16)
private String convertHexToIP(hex) {
	[convertHexToInt(hex[0..1]),convertHexToInt(hex[2..3]),convertHexToInt(hex[4..5]),convertHexToInt(hex[6..7])].join(".")
private Boolean canInstallLabs()
	return hasAllHubsOver("000.011.00603")
private Boolean hasAllHubsOver(String desiredFirmware)
	return realHubFirmwareVersions.every { fw -> fw >= desiredFirmware }
private List getRealHubFirmwareVersions()
	return location.hubs*.firmwareVersionString.findAll { it }
def convertBulbListToMap() {
	try {
		if (state.bulbs instanceof java.util.List) {
			def map = [:]
			state.bulbs.unique {it.id}.each { bulb ->
				map << ["${bulb.id}":["id":bulb.id, "name":bulb.name, "hub":bulb.hub]]
			state.bulbs = map
	catch(Exception e) {
		log.error "Caught error attempting to convert bulb list to map: $e"
def ipAddressFromDni(dni) {
	if (dni) {
		def segs = dni.split(":")
		convertHexToIP(segs[0]) + ":" +  convertHexToInt(segs[1])
	else {
		null
def getBridgeDni() {
	state.hostname
def getBridgeHostname() {
	def dni = state.hostname
	if (dni) {
	else {
		null
def getBridgeHostnameAndPort() {
	def result = null
	if (dni) {
		result = convertHexToIP(segs[0]) + ":" +  convertHexToInt(segs[1])
	log.trace "result = $result"
	result
