@tslagle13 below is the code that Iām using.
* Philio PSM01 Z-Wave Multi-sensor. Detects door/window opening, ambient light, ambient temperature
* Capabilities to enable: battery, contact, illuminace, temperature, poll, refresh, sensor
* Author: SmartThings, jscgs350
* Date: 2013-11-3, 2014-3-12
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: "Door Sensor", author: "jsconst@gmail.com") {
capability "Contact Sensor"
capability "Temperature Measurement"
capability "Sensor"
capability "Illuminance Measurement"
capability "Battery"
capability "Refresh"
capability "Polling"
simulator {
status "open" : "command: 3003, payload: FF"
status "closed" : "command: 3003, payload: 00"
for (int i = 0; i <= 100; i += 20) {
status "temperature ${i}F": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(
scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1).incomingMessage()
status "luminance ${i} lux": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(
scaledSensorValue: i, precision: 0, sensorType: 3).incomingMessage()
for (int i = 200; i <= 1000; i += 200) {
status "battery ${i}%": new physicalgraph.zwave.Zwave().batteryV1.batteryReport(
batteryLevel: i).incomingMessage()
tiles {
standardTile("contact", "device.contact", width: 2, height: 2) {
state "open", label: 'Front Door\nDoor\n${name}', icon: "st.contact.contact.open", backgroundColor: "#ffa81e"
state "closed", label: 'Front Door\nDoor\n${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
valueTile("temperature", "device.temperature", inactiveLabel: false) {
state "temperature", label:'${currentValue}Ā°',
backgroundColors:[
[value: 31, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("illuminance", "device.illuminance", inactiveLabel: false) {
state "luminosity", label:'${currentValue} ${unit}', unit:"lux"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:""
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main(["contact", "temperature", "illuminance"])
details(["contact", "temperature", "illuminance", "battery", "refresh"])
// Parse incoming device messages to generate events
def parse(String description)
def result = []
def cmd = zwave.parse(description, [0x31: 2, 0x30: 1, 0x84: 1, 0x20: 1, 0x70: 1, 0x80: 1, 0x01: 1])
if (cmd) {
if( cmd.CMD == "8407" ) { result << new physicalgraph.device.HubAction(zwave.wakeUpV1.wakeUpNoMoreInformation().format()) }
result << createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result}"
return result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.wakeupv1.WakeUpNotification cmd)
[descriptionText: "${device.displayName} woke up", isStateChange: false]
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
def map = [:]
switch (cmd.sensorType) {
case 1:
// temperature
def cmdScale = cmd.scale == 1 ? "F" : "C"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
map.unit = getTemperatureScale()
map.name = "temperature"
break;
case 3:
// luminance
map.value = cmd.scaledSensorValue.toInteger().toString()
map.unit = "lux"
map.name = "illuminance"
break;
case 5:
// humidity
map.unit = "%"
map.name = "humidity"
break;
map
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [:]
map.name = "battery"
map.value = cmd.batteryLevel > 0 ? cmd.batteryLevel.toString() : 1
map.unit = "%"
map.displayed = false
map
def sensorValueEvent(Short value) {
if (value) {
createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
} else {
createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
log.debug "Catchall reached for cmd: ${cmd.toString()}}"
Donāt forget you have to create a new device in the IDE. Sorry I didnāt see this till today. Hope it helps.
