Any idea why this does not work on reading input?
green_status, yellow_status, and red_status is always null.
* Input Monitor
* Copyright 2014
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Input Monitor (36 inputs)", author: "Tobias Mccurry", oauth: true) {
capability "Contact Sensor"
capability "Sensor"
fingerprint profileId: "0104", deviceId: "0402", inClusters: "0000,0001,0003,0009,0500", outClusters: "0000"
// simulator metadata
simulator {
// status messages
status "Red" : "Status reported within the last $red_status seconds"
status "Yellow": "Status reported within the last $yellow_status seconds"
status "Green": "Status reported within the last $green_status seconds"
preferences {
input name: "green_status", type: "number", title: "How long to wait for a ping?", description: "Set this to a low value in seconds", defaultValue: 60, required: true, displayDuringSetup: true
input name: "yellow_status", type: "number", title: "How long to wait for a ping?", description: "Set this to a medium value in seconds", defaultValue: 120, required: true, displayDuringSetup: true
input name: "red_status", type: "number", title: "How long to wait for a ping?", description: "Set this to a high value in seconds", defaultValue: 300, required: true, displayDuringSetup: true
// UI tile definitions
tiles {
standardTile("Alarm_Status", "device.AlarmState", canChangeIcon: true, canChangeBackground: true, width: 2, height: 2) {
state "Red", label: '${name}', icon: "st.Home.home2", backgroundColor: "#ff0000"
state "Yellow", label: '${name}', icon: "st.Home.home2", backgroundColor: "#cccc00"
state "Green", label: '${name}', icon: "st.Home.home2", backgroundColor: "#00ff00"
main ("Alarm_Status")
details ("Alarm_Status")
def init() {
state.startping = now()
log.debug("Start time: $state.startping")
log.debug("Green timeout: " + $green_status)
log.debug("Yellow timeout: " + $yellow_status)
log.debug("Red timeout: " + $red_status)
def installed() {
init()
def updated() {
//unsubscribe()
init()
def checktimeout(oldtime, newtime){
log.debug("Old time was: $oldtime")
log.debug("Current time: $newtime")
green_time_check = oldtime + $green_status
log.debug("Check green time: $green_time_check")
if (green_time_check > oldtime){
sendEvent(name:"AlarmState", value:"Green")
yellow_time_check = oldtime + $yellow_status
log.debug("Check yellow time: $yellow_time_check")
if (yellow_time_check > oldtime){
sendEvent(name:"AlarmState", value:"Yellow")
red_time_check = oldtime + $red_status
log.debug("Check red time: $red_time_check")
if (red_time_check > oldtime){
sendEvent(name:"AlarmState", value:"Red")
// Parse incoming device messages to generate events
log.debug("Description is: $description")
def value = zigbee.parse(description)?.text
def name = value && value != "ping" ? "response" : null
def result = createEvent(name: name, value: value)
log.debug "Parse returned ${result?.descriptionText}"
zigbee.smartShield(text: "updated").format()
def delay = green_status ?: 5
log.debug("delay assign: $delay")
if (value == "ping"){
log.debug "Ping Received!"
//sendEvent(name:"AlarmState", value:"Green")
state.pingtime = now()
log.debug("Ping time: $state.pingtime")
checktimeout(state.startping, state.pingtime)
//zigbee.smartShield(text: "Green").format()
if (description == "ping"){
if (value.contains(":")){
return result
