Figured it out. Reset the hub and tried connecting and it showed up! Yay!
Are you able to select what tone you want?
Is it possible to assign a specific tone for when a door opens?
I am able to set any of the 5 tones and any of the 3 volume levels when I set up the device. I don’t believe you can change either based on an event–I had to declare the sound and volume when I set up the device.
Thanks for replying, can you post pictures of the smartapp options if you don’t mind?
This is now on the official “works with SmartThings” list.
What is the name of the product that you used? I am not seeing the name.
