@kmugh I got this to work. What I noticed is that once the device type was created it failed to have any capabilities. Further once I pasted the code and saved it said that all changes had to be made in the metadate definition section. What I did was edited the code of @nickbailey and added the capabilities that I wanted. Please note that I also started from scratch once I realized this was what I needed to do. I have this working for 2 NPs. Here is the code:
- Nest Protect
- Author: nick@nickhbailey.com
- Date: 01.03.14
- INSTALLATION
- Create a new device type (https://graph.api.smartthings.com/ide/devices)
Capabilities:
Battery
Carbon Monoxide Detector
Polling
Smoke Detector
- Create a new device (https://graph.api.smartthings.com/device/list)
Device Network Id: Your Choice
Type: Nest Protect (should be the last option)
Hub/Group: Leave blank
- Update device preferences
Click on the new device to see the details.
Click the edit button next to Preferences
Fill in your Nest login information.
To find your MAC Address, login to http://home.nest.com. Click the Protect
icon. Open the right-hand side bar, open Nest Protect Settings, choose the Nest Protect
you are adding, open Technical Info, copy the value next to 802.15.4 MAC.
- Copyright © 2014 Nick Bailey nick@nickhbailey.com
- Permission is hereby granted, free of charge, to any person obtaining a copy of this
- software and associated documentation files (the “Software”), to deal in the Software
- without restriction, including without limitation the rights to use, copy, modify,
- merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
- permit persons to whom the Software is furnished to do so, subject to the following
- conditions: The above copyright notice and this permission notice shall be included
- in all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED “AS IS”, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
- INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
- PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
- HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
- CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
- OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
- Overall inspiration and Authentication methods originally developed by Brian Steere
- as part of the Nest thermostat device type: https://gist.github.com/Dianoga/6055918
- and are subject to the following:
- Copyright © 2013 Brian Steere dianoga7@3dgo.net
preferences {
input(“username”, “text”, title: “Username”, description: “Your Nest username (usually an email address)”)
input(“password”, “password”, title: “Password”, description: “Your Nest password”)
input(“mac”, “text”, title: “MAC Address”, description: “The MAC Address of your Nest Protect”)
// for the UI
metadata {
// Automatically generated. Make future change here.
definition (name: “Nest Protect Aug”, namespace: “NP”, author: "nick@nickhbailey.com") {
capability "Polling"
capability "Battery"
capability "Carbon Monoxide Detector"
capability “Smoke Detector”
simulator {
// TODO: define status and reply messages here
tiles {
valueTile("smoke", "device.smoke", width: 2, height: 2){
//state ("clear", label: "OK", unit: "Smoke", backgroundColor:"#44B621")
//state ("detected", icon:"st.alarm.smoke.smoke", label:"SMOKE", backgroundColor:"#e86d13", unit: "Smoke")
//state ("tested", label:"TEST", backgroundColor:"#003CEC", unit: "Smoke")
state "smoke", label: 'Smoke ${currentValue}', unit:"smoke",
backgroundColors: [
[value: "clear", color: "#44B621"],
[value: "detected", color: "#e86d13"],
[value: "tested", color: "#003CEC"]
valueTile("carbonMonoxide", "device.carbonMonoxide"){
//state("clear", backgroundColor:"#44B621", unit: "CO")
//state("detected", label:"CO", icon:"st.alarm.smoke.smoke", backgroundColor:"#e86d13", unit: "CO")
//state("tested", label:"TEST", icon:"st.alarm.smoke.test", backgroundColor:"#003CEC", unit: "CO")
state("carbonMonoxide", label: 'CO ${currentValue}', unit:"CO", backgroundColors: [
valueTile("battery", "device.battery"){
//state("OK", backgroundColor:"#44B621", unit: "Batt")
//state("Low", label:"Low", backgroundColor:"#e86d13")
state("battery", label: 'Battery ${currentValue}', unit:"battery", backgroundColors: [
[value: "OK", color: "#44B621"],
[value: "Low", color: "#e86d13"]
standardTile("refresh", "device.smoke", inactiveLabel: false, decoration: "flat") {
state "default", action:"polling.poll", icon:"st.secondary.refresh"
main "smoke"
details(["smoke", "carbonMonoxide", "battery", "refresh"])
def auto() {
log.debug “Executing ‘auto’”
def poll() {
log.debug "Executing ‘poll’"
api(‘status’, []) {
data.topaz = it.data.topaz.getAt(settings.mac.toUpperCase())
data.topaz.smoke_status = data.topaz.smoke_status == 0? "clear" : "detected"
data.topaz.co_status = data.topaz.co_status == 0? "clear" : "detected"
data.topaz.battery_health_state = data.topaz.battery_health_state == 0 ? "OK" : "Low"
sendEvent(name: 'smoke', value: data.topaz.smoke_status)
sendEvent(name: 'carbonMonoxide', value: data.topaz.co_status)
sendEvent(name: 'battery', value: data.topaz.battery_health_state )
log.debug settings.mac
log.debug data.topaz.wifi_mac_address
log.debug data.topaz.smoke_status
log.debug data.topaz.co_status
log.debug data.topaz.battery_health_state
def api(method, args = [], success = {}) {
if(!isLoggedIn()) {
log.debug "Need to login"
login(method, args, success)
return
def methods = [
'status': [uri: "/v2/mobile/${data.auth.user}", type: 'get']
def request = methods.getAt(method)
log.debug "Logged in"
doRequest(request.uri, args, request.type, success)
// Need to be logged in before this is called. So don’t call this. Call api.
def doRequest(uri, args, type, success) {
log.debug “Calling $type : $uri : $args”
if(uri.charAt(0) == '/') {
uri = "${data.auth.urls.transport_url}${uri}"
def params = [
uri: uri,
headers: [
'X-nl-protocol-version': 1,
'X-nl-user-id': data.auth.userid,
'Authorization': "Basic ${data.auth.access_token}"
body: args
if(type == 'post') {
httpPostJson(params, success)
} else if (type == 'get') {
httpGet(params, success)
def login(method = null, args = [], success = {}) {
def params = [
uri: ‘https://home.nest.com/user/login’,
body: [username: settings.username, password: settings.password]
httpPost(params) {response ->
data.auth = response.data
data.auth.expires_in = Date.parse('EEE, dd-MMM-yyyy HH:mm:ss z', response.data.expires_in).getTime()
log.debug data.auth
api(method, args, success)
def isLoggedIn() {
if(!data.auth) {
log.debug "No data.auth"
return false
def now = new Date().getTime();
return data.auth.expires_in > now
