I canât find the dimensions either, but I just measured the devices with a caliper. All units in inches (sorry). The motion sensor has a weird tapered shape, but is 2 inches at its thickest.
I have no way to confirm this, but the hardware looks like it could be essentially the same as the Schlage Nexia Motion Sensor (and possibly the Ecolink Motion Sensor).
There are differences in at least the firmware, though. The âTESTâ jumper doesnât work on the Monoprice, and the sensitivity setting, although appearing to work, behaves differently compared to the Schlage sensor. These features are also completely undocumented on the Monoprice sensor.
The Monoprice sensor also reports temperature, but I am unsure where it gets that from. It wouldnât surprise me if all the Sigma Designs Z-Wave modules had an integrated temperature sensor. Maybe someone from SmartThings can shed some light on this (if not prevented by NDA).
The hardware could come from the same supplier as those other sensors. Alternatively, it could be some cheap knockoff / pirated design, or simply be an invocation of some Z-Wave motion sensor reference design.
The sensitivity setting on the Monoprice sensor does work, but in the different modes, sensitivity is not exactly equivalent to that of the Schlage sensor. This is from my own experience, testing these sensors in a totally not controlled environment
This is the main take away from my comments:
Hardware wise, the Monoprice sensor looks like a re-packaged Schlage sensor
The âTESTâ feature (quick cool-down interval) is not functional on the Monoprice sensor. It works on the Schlage.
The sensitivity setting is undocumented on the Monoprice sensor, but it appears to work.
The sensitivity of the Monoprice sensor in the different modes (Default, âPET1â, âPET2â) is not exactly equivalent to that of the Schlage sensor in the respective mode.
I have no problems with the Monoprice sensor. With sensitivity set to âPET1â it correctly ignores my small dog, while still being plenty sensitive to human motion.
just wanted to post that I did get two of these and I like them. Iâd say the only negatives are the 5 minute time out for motion and that I canât see battery level?
Anyone know how to get the battery to show up? I do like how they show temperature
I thought the battery wasnât showing up because it didnât get the info yet - I just hooked my motion up yesterday. CrapâŠIâm hoping it is in there somewhere and it just needs to be identified in the battery type.
Iâm not positive but I believe itâs because Iâm using the aeon multisensor device type and itâs not reading the battery properly. same thing with the utilitech siren. you have to use the fortrezz device type, which is wired, so it doesnât pull battery.
Perhaps these motions need their own device type? Iâm just a consumer not a programmer.
I wasnât able to retrieve the battery fuel level from the device. It looks like it doesnât implement the Z-Wave Battery Command Class (0x80) at all. The Door/Window sensor, on the other hand, does. It is entirely possible that I am just missing something.
I installed your device type. But my question is does this do anything other than just clean up the things view? Even if that is the case I like it. Thanks!
Yeah, thatâs pretty much it. It culls all the tiles for the sensor values that it doesnât report - as opposed to the Aeon Multi Sensor.
In addition to that, the first shipment of the motion sensor used to report its temperature value in degrees Celsius, and the device handler converts that to Fahrenheit. I am not sure if the sensor now ships reporting degrees Fahrenheit from the factory.
Did you submit this so it can get added to the standard list of devices? I assume that is something that can be done through IDE? I would love for this to just work âout of the boxâ without having to connect to the IDE to âfix itâ
I have not explored that option, @brianlees. This was before user submissions of device handlers and SmartApps were accepted. I am unsure what the proper procedure is for submitting this as an official device handler. Iâll see what I can find out. Thanks!
