I’m hoping someone can help me out. I have a Kwikset 910 z-wave lock. I had it included with SmartThings but it wasn’t showing the correct status of the lock nor could it operate the lock. So I did an exclude in SmartThings app and removed the Kwikset lock. Now I can’t get it added again. When I press the button below the Programming Instructions it lights up both red and yellow for about 4 seconds then red for 1 second and then turns off. The app just spins and spins looking for new device.
I took the lock off the door and put it right next to the SmartThings hub and it does the same thing.
I have tried going into the app and doing a general exclude again and same results. I have pulled the batteries, pressed program 3 times and waited 10 seconds. Then put batteries back in and pressed the button and same results.
I’m almost at my breaking point, any advice would be appreciated.
Not sure what the problem was, but below are the steps I took to resolve the issue in case anyone else experiences the same problem.
I tried excluding on the SmartThings hub and that wasn’t working at all. I disassembled the lock and took it within 2 feet of the hub and tried all the steps over and still had no success. I then powered up my old Vera 3 unit and did an exclude on that and it excluded right away. I tried to include it in SmartThings and still nothing. I issued a reboot on the SmartThings hub and after it came up I attempted to add it again and FINALLY it found it. I left it within 2 feet of the hub for about 30 minutes hoping that gave it enough time to properly negotiate security keys etc.
The lock finally works. I wouldn’t call it great, but it’s working. It was a pain to get it setup.
