Anybody tried to use a hue with a wall dimmer switch?
I’m turning various lights around the house to 10% red when motion is detected at night and my app knows to turn on the corresponding switch if it was off. Unfortunately, the Hues come up at 100% white when powered on. That defeats the purpose of using dim red to avoid exposure to bright light at night.
So I was wondering if I can set the dimmer to 1%, change the color and intensity values for the Hues and then bump the dimmer up to 100%.
If the switch is off, I need to turn it on first. At which point the hues come up 100% white before the color and intensity message gets to them. So this doesn’t work as a subtle motion-activated night light.
I modified the power outage app to turn my Hues off (under certain circumstances) when power is restored after an outage. You’ll need a powered, battery equipped device like the original Smartsense motion to use it, but it is effective.
Getting this error when power is restored and it tries to kill my lights
error
groovy.lang.MissingMethodException: No signature of method: script1409585806724651476322.offSwitches() is applicable for argument types: () values: @ line 77
